| 6.0L Exterior Discussion Body and Accessories Talk |
Is it possible to have 20's on 35's with just a leveling kit? Thinking about going for it, but curious to see if there positive or negative feedback. Pics would be killer. Keep in mind i have a 03 f250 4x4 with a basic 2.5" leveling kit right now. thanks
I'm pretty sure you will not have a issue doing this. My Ready Lift leveler says you can run up to a 37" (which I wouldn't). You need to make sure you have the proper offset. I don't have the numbers in front of me, easy to find.
Back Spacing is key. I had a set of 18x10's with 4.5" BS on 33x12.5 and they rubbed at full lock on the inner fender. But then again I have seen a few leaf sprung trucks running the combo that you want without any issues.
-French |
Thanks for the info. Looks like I found a set up that would work out. Anyone have pics running this same combo?
