Anyone put rear blocks in w/ a leveling kit? - Ford Powerstroke Diesel Forum
Old 02-15-2010, 12:55 PM
I put a 2.5" kit up front and now I'm wanting to put in some rear lift blocks to even it out. The front is currently sitting about 1 1/4" higher than the rear. I can't really decide between a 3, 3.5, and 4" block to swap into the rear. Have any of you done this and if so, what size block did you use and do you have pics??
Old 02-15-2010, 01:28 PM
KING of BLING!
Most people go with the 4" f350 stock block. What leveling kit do you have?
Old 02-15-2010, 01:46 PM
I have 2.5" top gun spacers. I've been trying to get f350 blocks but the stealership wants a sh*tload for them and the bolts. I've been trying to find some on here and other sites but noone has any they'd sell. The issue i'm running into is the 350 blocks are actually 3 5/8" which would be about perfect so the 4" blocks would put the forward rake back in it and i can't find a 3.5" block kit with bolts...
Old 02-15-2010, 03:07 PM
I have the exact same spacers but it only put my front 3/4" higher than the rear. Don't care for the look so I am going to get the 4" blocks to rectify it. Have you seen these?
4" Readylift Block Kit
That should put you back a tad high on the rear, probably not enough to really notice less you look real hard. Not sure how they compare to dealership prices though.
Old 02-15-2010, 04:14 PM
i'm kind of leaning towards the 4" blocks as well. FWIW, I have found 4" block kits that include the u bolts for much less than the readylift blocks. suspension connection has a ton of skyjacker blocks and bolts for under $90
Old 02-15-2010, 04:23 PM
I have 2.5 in spacers and the readylift 4'' block kit in the back....
Old 02-15-2010, 04:24 PM
if anyone has any pics of a truck leveled with a 2.5 kit in front and 4" blocks in back ide love to see
^beat me to it^
Old 02-15-2010, 04:25 PM
Mine is a leaf truck but i have a 3.5'' kit in the front and it had stock F250 rear, i switched the 2'' block out with a 3'' and it sits perfect. I already had longer u-bolts so i ordered the block from Newtons lift off of ebay. They have rear block up to 6'' by 1/2'' steps, so you could get a 3.5'' or 4''. And then pick up some u-bolts at almost any 4x4 shop.
Old 02-15-2010, 04:57 PM
Here is a ReadyLift 2.5" Leveling Kit with the ReadyLift 4" Rear Block kit with Measurements on an 05 250 CCSB
Leveling Kit from Raul Updated with pics
