Yes they are leafs, the truck has the FX4 package on it. I dont know if that will make a difference. So what I am getting so far is they will fit with some slight rubbing. Correct?:thumb:
I have one size smaller than that with a 4" lift and they rub occasionally (probably on the mudflaps). So if you were to bump the axle forward a hair and possibly trim the front plastic valence I think you should be OK but every truck is different.
I have 315/70's on my 04 leaf. It will only rub a tiny tiny bit under full lock, and every now and then when I am backing out of a somewhere and have to cut it and drop off a curb at the same time. I am aware of it, and just dont put the truck in full lock, close but not all the way. Good luck
I had them on my truck for about 2 years now and no problems at all. I had them when it was stock, and then now with the leveling kit and they didn't rub either way.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
