Brighter Fogs - Ford Powerstroke Diesel Forum
Old 12-22-2009, 09:21 PM
Brighter Fogs
Well I am always tinkering when I have to work on something so why should replacing a fog light be any different. What I did was use a 9005 bulb which is 23 watts brighter and doesn't have a diffuser tip. Fogs are now much brighter. Maybe too bright for real fog. This was an 05 superduty FYI others may be different. You may need to slightly notch the top tab, I didn't but you can see a little notch on the 9145 bulb. Also you can get crazy with this and get up to 100 watt bulb, xenon, yellow, blue, purple, even LED in a 9005. I just used a regular 65 watt, there are also silver stars etc. avaliable in 65 watt 9005 if you desire more white light out of em with out upping the current draw. The 65 watt doesn't seem to be creating any extra heat in the wire due to the extra amp draw but the lens gets alittle warmer but not much. Just thought I would share a neat find.
Old 12-23-2009, 06:38 AM
Nice experiment. Keep an eye on your housings they may start to deform/melt from the extra heat. For the price of HID kits now it's really the best option for brighter fogs. For example you can get the DDM 35w kit now for $49.00, includes lifetime warranty. That makes it a no brainer in my opinion.
Old 12-23-2009, 08:45 AM
Yeah $49.00 is pretty cheap for HIDs. The standard 9005 cost me 18 bucks for the pair. Much brighter than standard and cheap. No where near enoough heat to do annything to the lens, I have been keeping an eye on it. But HIDs are cool and hard to beat for under 50 bucks.
