Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 11-06-2009, 08:29 PM
wacko37 wacko37 is offline
Lift questions
i went to 4wheelparts and they said i only need the suspension to lift my truck more. I went to another shop here and thay said i need the FULL kit to include trac bar adjustment and pitman arm ect. whats your guy's thoughts? i have a 4" lift now and lookin to get front hangers and rear springs.
Old 11-06-2009, 08:56 PM
bondsman bondsman is offline
How much further up are you going???? You don't "need" a whole kit. If you are getting rear springs and front shackles, then all you would need is an adjustable tracbar (maybe a trackbar drop bracket - I have an extra one for an 05, don't know if they are the same). You should already have the drop pitman arm. You will also need longer shocks... Depending on height also look at brake lines, carrier bearing shim kit (definitely need the shim kit or an adjustable carrier bearing mount or you will have some crazy vibrations)
Old 11-06-2009, 09:58 PM
im goin up to either 6.5 or 8 havnt decided yet
