lift blocks - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-05-2007, 05:37 PM Thread Starter
im fat and ugly
stump0331's Avatar
lift blocks
ive got some 4" lift blocks and new u bolts for the rear, im about ready to install em was wondering what the easiest ,(safest) way to install em
all i have to work with is a floor jack and some jack stands, may be able to get another jack.
want to put em in in my driveway
2004 Excursion
stump0331 is offline
post #2 of 5 Old 03-05-2007, 06:19 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
If you have big enough jack stands I'd jack it up and put the jack stands on the fram rail right next to the front spring mount for the rear springs. Chauk the front wheels then use the jack to lower/raise the rear axle. That's how I'd do it.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 5 Old 03-05-2007, 06:22 PM Thread Starter
im fat and ugly
stump0331's Avatar
thats what my intial thought were
2004 Excursion
post #4 of 5 Old 03-05-2007, 09:39 PM
dustindiesel's Avatar
if u had access to an engine hoist id use it to lift the rear end from the reciever hitch and then loosen the springs and slide the block in..i used that method for many of my lifts
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #5 of 5 Old 03-06-2007, 04:03 AM Thread Starter
im fat and ugly
stump0331's Avatar
i might take it to work and use a fork lift to raise from the hitch
2004 Excursion
