okay, I have a 2006 Lariat F-250 so I had signals, running lights and power to adjust, JUST like the mirrors I just received. The plugs werent the same so I figured NBD, I can plug and play... I have the ground connected, the clearance lights work, the signal and the heat, BUT, here's where it gets tricky, no matter what I do with the rest of the wires, the mirror either doesn't move at all, OR it only moves 2 directions and not the others! (I can't remember each way). Had to come in and finally ask. Literally trying to do it right now. I have looked and looked but it seems like if I had non signal mirrors before then there are TONS of how to's but I havent found one thing that can explain my situation. Any help would be great.
I have:
on the truck (pig tail I took of old mirror): on the mirror:
Black (ground) Black
Brown (running light) white
mint green (turn signal) blue
Blk-white tracer (heat) gray
Im left with:
2 yellow yellow
blue green
red red
Tried everything all different ways. Cant even think straight anymore
I have:
Im left with:
2 yellow yellow
blue green
red red
