xl headlighs - Ford Powerstroke Diesel Forum
Old 08-18-2009, 06:19 PM
xl headlighs
i just got a good deal on a 06 f250 xl. it has the square recessed headlights and was wondering if harley davidson or lariat headlights would fit. also if it wouldbe plug and play or if i would have to wire them up. thanks
Old 08-18-2009, 06:21 PM
They should bolt right up but you will have to splice in 9007 headlight bulb connectors though. Your current sealed beam connectors won't fit. Not a big deal though, just 3 wires.
Old 08-19-2009, 07:08 AM
It wouldn't be the 9007 connectors, they changed the connectors in 2005 to the H13 if I'm not mistakin.
-French
Old 08-19-2009, 08:32 AM
Feedback Score: 5 reviews
And the H13's suck..The H13 is quite possibly the stupidest design for a bulb ever foisted on the public. The terminals are so small that they overheat, even at stock wattages, and melt the plastic housing of the connectors. Higher than stock wattage bulbs are offered, but not recommended and no harness will fix the problem of to small of terminals.
Old 08-19-2009, 11:09 AM
Agreed
Get you a set of HD or XLT Headlights, and talk to Raul@StealthAutomotive and get you some HID's You will NOT be disappointed!
