Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 07-16-2009, 04:52 PM
zippy557 zippy557 is offline
Send a message via AIM to zippy557
Anyone have HIDs ??
Looking at maybe going with some hids for the headlights and foglights to gain some extra visibility. Just wondering if there is anything i should know about putting hids in these trucks or if it's easy. Any help would be appreciated, thanks
Old 07-16-2009, 05:34 PM
anaconda33 anaconda33 is offline
I have 6000k HIDs and I love them! My recommendation - make sure you get a relay kit to install them correctly off the bat - I didn't and had to redo them later on. Not too hard to install - I would recommend pulling the headlights instead of trying to jam your hands down behind the front clip. You'll have to remove the drivers side battery and battery tray to get enough room to get to the bulbs if you don't pull the headlights. Not too bad to install though.
Old 07-16-2009, 05:39 PM
justin in time stroker justin in time stroker is offline
Install is a breeze i have 8ks and love them will never run halogean bulbs ever again.But yes like stated above get the kit that has the relays.
Old 07-16-2009, 07:05 PM
Thanks for the quick responses, i am looking at a 6000k kit, i'll def get the relays just wanted to make sure it wasn't any harder then they make it out to be online.
Old 07-16-2009, 08:45 PM
f250krew f250krew is offline
blacknblack
DDM 35W & 55W Slim Ballast HID Kit: DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
some guy just put these on his ride and they are pretty cheap and he likes the kit i cant remember his name but i hope he chims in he look great
Old 07-17-2009, 11:25 AM
Dan"gerous" Dan"gerous" is online now
Any one have the Bi/kits? If so how quickly do the bulbs change from dim to bright; Can you still flash people?
Old 08-09-2009, 02:47 AM
jsr86 jsr86 is offline
i have the 6k hid lights with the hi-low capability. i didnt wire them up... hids are bright enough so brights werent a high priority imo... oh and you only need 1 relay. and a fuse if you wanna do it the right way.
Old 08-09-2009, 03:06 AM
Broo Broo Broo Broo is offline
Send a message via Yahoo to Broo Broo Send a message via Skype™ to Broo Broo
I have the bi/xenon 5000k 55w, but don't really ever use bright. You can still flash to pass, just hold the switch for a second or so. I did buy the relay but still have it sitting on the shelf as I don't have DRLs. Installation took about an hour. I would def recommend a DDM kit, the are cheaper than most, but the quality is great. I was really surprised when I got my kit.
