Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 06-30-2009, 09:36 PM
DunesRunner08 DunesRunner08 is online now
Does this sound right?
So I am messing with my SCT Tuner.... and I get to where I have to adjust my speedometer and it goes by rev's per mile and I Running a 40x15.50R22 Toyo Open Country M/T and i was trying to figure out all the numbers and I came up with the truck did 658.2 on the stock tires and with the 40's it is doing 524.1.... does this sound correct?
Old 06-30-2009, 09:43 PM
GM Duraturd GM Duraturd is offline
I got 504.025 revolutions per mile with the 40's. I may be wrong.
40 x 3.1427 (tire circumference in inches) = 125.708
5280 (feet in mile) x 12 = 63360 (inches in mile)
63360 / 125.708 = 504.025 rev/mile.
Make sense or am I missing something?
Old 06-30-2009, 09:47 PM
yeah but try the equation with the actual tire size from toyo's website.... 39.7
Old 06-30-2009, 09:50 PM
with that equation I got 508.1
Old 07-01-2009, 05:25 AM
topdwg topdwg is offline
This is where I go to calculate my revs per mile: Tire size calculator
It works with the metric system. If you have your tire size in the standard system, just figure the metric values first with this calculator and then go on to determine your revolutions per mile with the above calculator.
Metric Tire Conversion Calculator - Red Rock 4x4
Old 07-01-2009, 05:30 AM
I did it for you...
504...
Old 07-01-2009, 05:43 AM
DBM DBM is offline
most tire sites have the revs per mile on the page with their tire specs...Toyo lists that tire as 522 revs per mile
Old 07-01-2009, 08:55 AM
well then.... I am just going to plug in what Toyo says then... do you have a link to that page on their website?
Old 07-01-2009, 09:04 PM
DBM DBM is offline
here you go... http://toyotires.com/tires/suv-and-truck/full/OPMT/96
Old 07-01-2009, 09:17 PM
Thank you... I had the choice between 520 or 525 so I picked 520... hopefully my speedo will be correct....
for anyone with huge tires... this thing will adjust up to 46" or 48" I'd have to do the math, i highly suggest the SCT Livewire to anyone for its options and adjustability
