Leveling Kit - Ford Powerstroke Diesel Forum
Old 02-06-2007, 08:47 PM
Send a message via MSN to smokeshow101
Leveling Kit
I was wondering what's the biggest sized tires and rims i could go with if i put the leveling kit on my truck?
Old 02-06-2007, 09:15 PM
Hey smokshow, I've herd some of the guys going to 35s with a leveling kit, check some of the threads in general discussion and see what they have to say, it's a common subject, or you could do a search on leveling kits and see what comes up. But I'm sure one of the lifted guys will be along.
Gord.
Old 02-06-2007, 09:18 PM
My partner Larry runs 33s on his stock suspension 2000 Excursion.
Old 02-06-2007, 09:21 PM
I'm thinking a 33x12.5 would be the biggest tire you could run on an 9 or 10 inch wide rim without rubbing. If you stuck with 8's you may get a 35 under there. I had about 3.5 inches of lift on my '02, sitting on 35x12.5 and 18x10's. They rubbed at full turn on level ground.
James
Old 02-07-2007, 03:45 PM
Alright thanks guys. Just checkin right now. Dunno when ill do it but want to soon.
Old 02-07-2007, 06:02 PM
Thats what were here for hahaha.
Old 02-07-2007, 06:24 PM
Send a message via AIM to cumminskiller
i got 35's on mine with a leveling kit and the back jacked up like 2"
Old 02-07-2007, 08:45 PM
if i put those 35's on there with the leveling kit would i still be able to pull my 24' gooseneck trailer?
Old 02-10-2007, 02:05 AM
Here durka durka durka!
Send a message via AIM to EODguyJake Send a message via Yahoo to EODguyJake
I went with Rancho's 2.5 inch front spring replacement. It's a good kit. I run 285/75/R16s on 16x10 inch rims with no rubbing issues. But, I'm going back to an 8inch wide rim here soon. I've heard too many stories bout the 10inchers wearing out front end parts. Plus, I'm sure like all of you know, the power steering at low speeds is bad enough, and the 10in rim's bigger footprint doesn't help.
