08 Tail Lights on 05, Need Help... - Ford Powerstroke Diesel Forum
Old 06-24-2009, 11:09 AM
Hi Guys...
Anyone put 08 tail lights on yet? I picked them up at the dealer this am, and plan on installing them tonight.
Does anyone know for sure what needs to be modified? I plan on going to schucks auto supply to look for some pigtails that may work. I have to pull out the originally tailight to see what might need to be done.
I'm just checking to see if there are any tips or instructions that someone could provide??
Thanks
Old 06-24-2009, 11:11 AM
I would also like to know...
Old 06-24-2009, 12:21 PM
when i changed mine the only thing i did was cut the old backup light connector off and sautered 08 back up light on. The old turn, parking, brake light will fit in the 08 light so nothing needed there. Hope this helps. James
Old 06-24-2009, 12:33 PM
THanks this helps alot!
I'm going to the dealer to get the reverse light socket/bulb and going to cut off the old one like you did and intall it.
