Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 05-11-2009, 12:48 PM
dieselnut18 dieselnut18 is offline
keyless entry
i would like to add a factory keyless entry to my truck.....its an xlt package and i wouldve thought it would have one but it didnt come with my truck.......how hard would it be to find out if it has it or if i can add it?
Old 05-11-2009, 01:20 PM
Peppy Peppy is offline
just about impossible, the models that have factory keyless use a different windshield and the locking setup is a type "B" system (negative pulse) whereas without factory keyless it is a type "C" system (reverse polarity) However it's easy enough to add an aftermarket keyless entry but if your going to go that far you might as well put in a command start. If you need info on how to hook up an aftermarket setup pm and i'll send you a schematic
Old 05-11-2009, 02:38 PM
thatd be great how exspensive is it to add keyless lock and start.......what about the glow plug deal?
Old 05-11-2009, 03:55 PM
if you have a decent knowledge of automotive wiring and methods (soldering) its not that hard to do yourself as for cost it depends on your choice of module but basically your looking at anywhere from 50-500 bucks for the unit depending how fancy you go, as for the glow plugs the modules have a wait to start timer that works fine
Old 05-11-2009, 06:09 PM
where would be the best to find a module at?
Old 05-11-2009, 06:49 PM
ZMANN ZMANN is offline
buy an after market alarm I can remote start my truck and even open my toolbox http://www.youtube.com/watch?v=SPW_uksVsEk
Old 05-11-2009, 07:02 PM
choupique108 choupique108 is offline
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
id like to add the keypad for the doors, my truck already has keyless entry but where can i find the keypad and how hard is it to hook up?
Old 05-11-2009, 07:12 PM
you can buy them at pretty well any electronics retailer
