Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
  #11 (permalink)
Old 05-08-2009, 08:36 PM
06F250FX4 06F250FX4 is offline
Originally Posted by 03Powerstroker6.0 View Post
get a simple relay from autozone hook 85 to your remote turn on wire. 30 to parking brakewire and 87 and 86 to ground. works great
That is the correct method for the AVH-4000dvd. Cheap $4 relay from Autozone and some female connectors, and you can watch DVD's anytime you want.
  #12 (permalink)
Old 05-08-2009, 08:43 PM
guntersxr guntersxr is online now
sorry but im kind of an electrical what do all those numers mean? anyone have pics?
  #13 (permalink)
Old 05-08-2009, 08:54 PM
Those are the inputs and outputs on the relay. They are marked on the relay right next to each pin. This is a picture of a Bosch relay that also has an 87a terminal. Autozone relays are only 4 prong relays. But you should get the picture. Autozone relay will not have the center 87a prong.
http://i699.photobucket.com/albums/v...5/relaybot.jpg
  #14 (permalink)
Old 05-08-2009, 09:08 PM
sweet i think i can handle that, now when you say connect the 30 to the brake wire do you mean the wire coming off the unit that is supposed to hook to the brake lead or the actual brake lead?
  #15 (permalink)
Old 05-08-2009, 09:20 PM
Connect the amp remote wire on the head unit harness to 80. Parking brake wire from head unit to prong 30. Ground prongs 86 & 87. All connections to the relay are from the wiring harness of the avh-4000dvd.
  #16 (permalink)
Old 05-08-2009, 09:50 PM
you sir, are the man, thanks
  #17 (permalink)
Old 05-08-2009, 09:52 PM
colberjs colberjs is offline
Thats why I said wasnt it
I was gonna say that!!!
