need help 3 electrical problems - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-29-2014, 06:00 PM Thread Starter
My 06 6.0 xlt has 3 electrical problems I need some more insight on, the first is my radio nor my dome lights or anything else turns on or off when any of the doors are opened or closed replaced the relay already and don't know what to do from there, the second are my headlights my high beam work fine but my low beam are not getting any power I can give power to the fuse and they will turn on then also don't know where to go from here or what to test, and the last is my starter will not engage with the key I took a wire and ran it to the trigger wire to my batter and it cranked so I went to my relay and jumped I believe its the 30 slot to the 86 or 87 slot (the one across from 30) and did it nothing at all I also do have power coming from the trigger slot to trigger the relay even though it wont start when jumped any and all help is much appreciated
magnumv8 is offline
