No power to headlights?? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-29-2014, 05:05 PM Thread Starter
Short story....just got my truck back from the shop Thursday the 24th for head studs and couple other things. I also had them add two additional gauges in an overhead pod. Wasn't something I thought I had to check or be worried about, but when I went to leave Sat evening, no headlights. Running lights work, all my dash lights, and gauge lights work. I metered the connectors and I only have power going to the passenger side. I swapped my HID harness to that side, still nothing. Checked fuses, they all are good. I metered the headlight switch, and I have power going in and coming out. Any thoughts? I can't seem to find anything anywhere about headlight relays? Are there any? I will have a full write up later of why I am not taking the truck back to the shop who did the work. Any info helps, thanks guys!
2005 Excursion, 6.0L, 6" lift w/ 35's, AFE CAI Stage 2, CFM Large Mouth kit, 4" MBRP Turbo back straight pipe, SCT X3 with IDP tune, BD Boost fooler, Autometer gauges, EGT, boost, EOT, ECT, trans temp, oil pres, fuel pres, WW2, Bulletproof EGR, Bulletproof oiler cooler, BD Intercooler, Blue Spring kit, studed, Sinister t-stat & housing, DC Alternator(325amp), BD double stack trans cooler, Snow Performance MPG-MAX kit, and more to come!
scurshn is offline
