New speedometer issue - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-26-2014, 03:11 PM Thread Starter
I haven't found this in the search, so I need to make a thread.
After removing the IC to facilitate other maintenance, the speedo/cruise control aren't working. Everything was normal prior. All fuses are good, my Scan Gauge II reads a speed, I swapped in a new VSS in the axle, then replaced the OEM after cleaning, but still no speedo.
When I pulled the IC to check connections, I applied a small amount of Di-Electric grease to all three connectors because I read the connection is critical.
Any input would be GREATLY appreciated.
I am also posting this in General discussion for higher visibility.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #2 of 4 Old 08-05-2014, 07:02 AM
Quoted: 15 Post(s)
Sorry, I can't think of anthing that may have caused it! On second thought is your ABS system all intact?
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For This Useful Post:
Karls03 (08-05-2014)
post #3 of 4 Old 08-05-2014, 12:40 PM Thread Starter
WE HAVE A WINNER!!!
It would seem that I didn't ensure proper 12V KO to the Superlift speedo box when I reassembled things. So, lenzhotrod wins for suggesting that it was an ABS issue.
Thanks a lot, I knew someone on the org would come up with something I was missing.
Karls03 is offline
post #4 of 4 Old 08-05-2014, 06:51 PM
Quoted: 15 Post(s)
At first I had no answer, but I type so slow I thought of one. Glad it was the right one!
