Remote installers & gurus - intermittent no start - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-25-2014, 02:15 PM Thread Starter
This will be a longer post than it should be - I can't help myself - my father was a story teller too. I'm sorry.
So I bought the truck about a year ago and I love it. 2006, 6.0 with all the good things done to the engine - absolutely no concerns about the drivetrain so far. Just one annoying quirk related to the remote start.
The truck has what I have since learned is a Ford aftermarket 4-button remote start system. Its taken a year to get to where I feel I can accurately describe exactly what it does. I'd like someone to tell me why it does this and how to fix it.
Periodically, for no immediately apparent reason, we would get in the truck and turn the key and nothing would happen. I say "nothing" but actually the dash lights up, the glow plugs cycle, I hear the normal underhood noises but when I turn the key to engage the starter nothing happens - no click, nothing. Whenever this happened we initially had no understanding of what we would eventually do to solve the problem so it was annoying in the extreme. The truck ALWAYS starts if I use the remote start button - the problem only appears, very occasionally, when I try to start it with the key. So we were never stranded - just mildly annoyed on maybe 6 or 8 occasions. No big deal. Over the course of the year I have learned how to repeat the problem reliably and its very simple.
If I use the remote unlock then the truck will start every time using the key. If I unlock the truck with the key then it will never start using the key. Since we rarely lock the truck and almost always unlock it with the remote, the problem rarely appeared. Today I replaced the alternator and discovered that if I disconnect the batteries completely then that will also cause the problem. So just to be clear, after I reconnected the batteries when I turned the key I got a "no-starter situation" but as soon as I cycled the locks with the remote the truck started normally on the key. I have also learned that if I create the problem (unlock the door with the key) and then attempt to start the truck, I can subsequently start it using the big yellow wire on the passenger fenderwell, for whatever that is worth.
So now you know everything that I know. Will somebody please tell me what the problem is and how to solve it.
Thank you.
Several 7.3s in my past
Currently driving a 2006 6.0
bobofthenorth is offline
post #2 of 13 Old 07-25-2014, 03:22 PM
portcity_gt's Avatar
Quoted: 1361 Post(s)
Sounds like a normal theft deterrent, it wont start unless "disarmed" by the remote.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 13 Old 07-25-2014, 03:37 PM Thread Starter
That's what the guy who used to own the truck said. I find it hard to believe its normal behaviour but you could be right.
post #4 of 13 Old 07-25-2014, 03:41 PM
ZMANN's Avatar
Quoted: 1589 Post(s)
I agree with portcity '
it sounds totally normal for any alarm /theft deterrent
using the key and popping the door lock are the same as far as the truck knows so a good alarm won't let the key disarm with a door key if the remote was used to lock it
ps mine saved my truck when some theif popped my door lock at the handle
We Miss you Ronnie
ZMANN is offline
post #5 of 13 Old 07-25-2014, 03:46 PM
If it bothers you that much, any car stereo shop can bypass the starter interrupt relay.
post #6 of 13 Old 07-25-2014, 04:28 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 370 Post(s)
When you lock the doors with the button do you click it twice and make the horn blow?
If you do, you have activated the anti theft. If you don't then it is not activated.
I could be wrong but I'm pretty sure the above is accurate.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 13 Old 07-25-2014, 06:08 PM
StrokinAlaska's Avatar
I'm not a 6.0 owner but been installing for over 6 years. The Antigrind relay is acting up, bypass it by connecting the starter wire back together or drop a new spst relay in there.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #8 of 13 Old 07-27-2014, 09:37 AM Thread Starter
Never.
Which tends to support my belief that the behaviour I am seeing is abnormal.
post #9 of 13 Old 07-27-2014, 09:38 AM Thread Starter
Any tips on wire colours to look for? I'm assuming I could jumper the relay out so that I can test this before I replace the relay, as long as I can identify which relay to bypass.
post #10 of 13 Old 07-27-2014, 06:40 PM
Not sure on factory systems. But the relay will have ignition input, ground and starter car side and key side and ground while armed or locked and security armed. Your starter wires are 87 and 87a . the relay is connecting the starter wires together when the ignition is powered as long as the security system is unlocked. So if u just connect the cut starter wire together ull be good to go
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
VisionX Cannon 4.7"
VisionX Cannon 6.7"
Hids
Alpine INE-S920HD
Tint
