Trailer lights - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-21-2014, 11:16 AM Thread Starter
Trailer lights
Hi guys. This is my first post! Recently purchased a 2005 F350 6 litre Power stroke diesel. My trailer signal/stop lamps work. My trailer head lamps don't. They were working for a bit and now there not. Any suggestions? Thanx
Dennis.t is offline
post #2 of 9 Old 07-22-2014, 09:37 AM
ZMANN's Avatar
Quoted: 1346 Post(s)
trailer head lamps ? i usually tow my trailer from behind so I don't have headlamps on it ;-)
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 07-22-2014, 09:40 AM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
I'm guessing you mean tail or running lights?
Check your owners manual to see if there is separate fuse in the Power Distribution box under the hood for trailer running lights.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #4 of 9 Old 07-22-2014, 10:54 AM Thread Starter
Can the smart *** remarks dude.
Dennis.t is offline
post #5 of 9 Old 07-22-2014, 10:56 AM Thread Starter
Yah, cant seem to see where the trailer running lights fuse would be in the fuse box. I find the fuse diagram not labeling the items very clearly.
Dennis.t is offline
post #6 of 9 Old 07-22-2014, 11:09 AM
ZMANN's Avatar
do you have a test light or multimeter ?
or are you sure the problem is on the truck side of the connections
do you have an owners manual with fuse locations ?
if not use this no need for the log in just fill in the truck specs
https://owner.ford.com/servlet/Conte...OwnerGuidePage
smartass comments are a given on here but there is no charge ;- )
We Miss you Ronnie
ZMANN is offline
post #7 of 9 Old 07-22-2014, 11:20 AM Thread Starter
Yes,its on the truck side, cause both of my 2 trailers, running lights not working when hooked up to the truck.
Dennis.t is offline
post #8 of 9 Old 07-23-2014, 08:03 AM
Quoted: 298 Post(s)
Garage
Using the manual from the link above (2005 F350), Passenger Compartment Fuse Panel. Page 219, Fuse 38 20A* - Trailer Tow Park Lamps. * - Indicates a mini fuse.
Page 218 shows the fuse box layout.
My Truck Garage:
Tow Toy Garage :
post #9 of 9 Old 07-23-2014, 09:30 AM Thread Starter
Thanx dude, I will try that!
Dennis.t is offline
