6.0 AC Module stopped working - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-14-2014, 12:59 PM Thread Starter
I had my ac blowing full blast first of few times I have ever used my ac. Pulled up to a light put it in park raised the wheel to turn to the back seat when I turned back around my ac was shut off completely! No lights work, no air nothing! I tried the old unhook the battery, fuse check and turning my lights on and off tricks but nothing worked. I was told to make sure my heated seats were workin or not and they still come on automatically. If anybody has been in this situation before please let me know any input is greatly appreciated! Hoping I just pulled a wire loose but expecting to have to have the module replaced.
JT927 is offline
post #2 of 8 Old 07-15-2014, 10:31 PM
05_HARLEY_F250's Avatar
Which module do you have?, are there controls in the steering wheel?
It sounds like there's something going on in your tilt, mine does it when the I tilt all the way down and sometimes at random, never could find the problem wire and after replacing the fuse every time it did it I bought a 15A mini buss breaker at autozone and modified my fuse box cover to allow it.
05_HARLEY_F250 is offline
post #3 of 8 Old 07-16-2014, 02:03 PM Thread Starter
Yeah there's steering controls and it's the automatic climate control unit.
JT927 is offline
post #4 of 8 Old 07-16-2014, 02:36 PM
ZMANN's Avatar
Quoted: 1477 Post(s)
heated seats come on automatically ?
do you have the fuse locations so you can verify the AC fuses are OK ??
any thing else out at all ? dome ? dash wise ? ETC
radio ? if the radio works do any of the other steering wheel controls work ?
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 07-17-2014, 10:59 AM
Couldn't swear to it but I think the A/C control is on it's own fuse, I can't remember. I've pulled half the interior out and could never find the problem, it's bound to be in the steering column, I've only had it go out once since I installed the breaker but then again I don't move my tilt much.
post #6 of 8 Old 07-17-2014, 12:08 PM Thread Starter
yeah my heated seats still come on automatically and my trailer brake module thingy still comes on and works. all wires underneath steering are plugged in tightly. I appreciate the help guys I just hope I can find the problem elsewhere before having to take the dash apart!
JT927 is offline
post #7 of 8 Old 09-14-2014, 02:42 PM
firstresponder01's Avatar
Mine just did this today. Heated seats work as well as the all the steering controls. Did you eve find out what it was?
firstresponder01 is offline
post #8 of 8 Old 09-15-2014, 04:17 PM Thread Starter
Yes mine was a fuse but the tricky thing was I only checked one fuse check every fuse that has do do with the module because I think there is a couple fuses that work the module. Now she runs like a charm let me know how it goes!
JT927 is offline
