L.E.D Reverse Lights - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By trophy_23
post #1 of 6 Old 07-11-2014, 06:06 PM Thread Starter
AaronB.F250's Avatar
Quoted: 2 Post(s)
Hey guys just a quick question that im sure many have asked but I haven't been able to track it down yet. I was looking to installing L.E.D reverse light but was wondering if they made a bulb that fits in stock housing of tail light. I have HID fogs so the idea of putting in a resistor is fine just didn't want to have big bulky light housings hanging below my bumper. Thanks in advance
Aaron
2006 CCLB Lariat 6.0
4"D.P 5" straight pipe. APR studs. EGR delete. H&S mini maxx. Dummy plugs. Stand pipes. LED interior, Reverse lights, 6K Fogs. High Idle mod. Daily Driver
2009 F-450 6spd 6.4
9' enclosed utility body. DPF/CAT Delete. Money maker
AaronB.F250 is offline
post #2 of 6 Old 07-12-2014, 07:30 AM
trophy_23's Avatar
They do make some to go in the stock reverse spot. Check out Retro-solutions LED's. I put the 9W reverse bulbs in and I am very impressed!
dfuzz78 likes this.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
Last edited by trophy_23; 07-12-2014 at 07:31 AM. Reason: see the year of the truck now
trophy_23 is offline
post #3 of 6 Old 07-12-2014, 07:32 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Yep, Retro-Solutions is your answer for anything LED!
Retro-Solutions.net
http://retro-solutions.net/product-l...g1-cid121.html
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #4 of 6 Old 07-13-2014, 04:41 PM
2006F350's Avatar
I got some of these 4 for $20
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #5 of 6 Old 07-18-2014, 05:09 AM
RECON & ORACLE also makes some.
RYCRKT is offline
post #6 of 6 Old 07-18-2014, 12:50 PM
HP MACHINE's Avatar
Quoted: 105 Post(s)
Diode Dynamics . Check out one of the random banners at the top of these forums .
Great lights , Fast service - what more could you ask for ?
Oh' and good prices also.
I just put back up and front signals in my truck , love em'
HP MACHINE is offline
