Fusable Links? Alternater wiring. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-10-2014, 04:44 PM Thread Starter
BACKGROUND: 06 PSD. My charging system failed the other day, never charging over 11.3V. My batteries are new and test well after charging so I was pretty sure it was an alternater issue (no change in Volts after starting). I pulled the alternater and the rectifier checks out as still one way. The alternater is a relatively new (less than 10K) 200A Db electrical just out of warranty. So I have ordered a new regulator and a backup cheapo alternater.
When I pulled the alternater and put it on the bench, no less than 3 globs of solder fell out of it. My concern is that maybe a glob created a short in the windings that blew something. I keep reading about fusible links but can't find them. Can anyone help on these?
cemiii is offline
post #2 of 3 Old 07-11-2014, 10:49 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 447 Post(s)
Garage
Get yourself a 175 amp fuseable link for the output of that alt. they are available at Auto Zone and Oriellys they are flat with 3/8 holes on each end for mounting to cables and battery clamps.
You could try a circuit breaker but I don't think I would trust it to last long term.
They are a wise move.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
The Following User Says Thank You to mhatlen For This Useful Post:
cemiii (07-14-2014)
post #3 of 3 Old 07-12-2014, 06:47 AM
Quoted: 50 Post(s)
Mega high amp fuses are another good option.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
The Following User Says Thank You to skanj0 For This Useful Post:
cemiii (07-14-2014)
