ae question - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-05-2014, 07:42 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
ae question
I need to find out what is cycling on and off that is driving my serpentine belt crazy. Will the AE computer monitoring system do this?
Were is the best place to pick this up? Thanks and happy 4th!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 14 Old 07-05-2014, 09:50 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 414 Post(s)
Sure its not A/C?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
The Following User Says Thank You to LoxDiesel For This Useful Post:
kinnisoj (07-05-2014)
post #3 of 14 Old 07-05-2014, 11:40 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I'm starting to think so.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 14 Old 07-05-2014, 11:45 AM
ZMANN's Avatar
Quoted: 1672 Post(s)
has to be IMHO
unplug it for a test
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
post #5 of 14 Old 07-05-2014, 02:28 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
If it is the ac, would the be signs of a over charged ac? Or a bad compressor? Needs rev x???
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 14 Old 07-05-2014, 03:55 PM
LoxDiesel's Avatar
Quoted: 414 Post(s)
Another thing to consider. Have you ever changed the tensioner? The next pulley after the compressor is the tensioner. But at the same time if the compressor is hard to turn (going bad) then it will cause your belt to squeak.
Also on the back side of the belt is it dried/cracking? That's a sure sign to change your belt.
@loxdce
post #7 of 14 Old 07-05-2014, 04:18 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
New tensioner, new belt. Well just a year and a half old.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 14 Old 07-05-2014, 04:30 PM
ZMANN's Avatar
IMHO
if you AC cycles a lot you should be able to hear and identify it as the source and it's usually because a pressure switch
is making breaking a circuit do to a charge condition
We Miss you Ronnie
ZMANN is offline
post #9 of 14 Old 07-05-2014, 04:36 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Well it only seems to be a issue after the truck is warmed up and running down the highway. I can't reeley hear a click.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 14 Old 07-05-2014, 05:08 PM
LoxDiesel's Avatar
Quoted: 414 Post(s)
Ride around with the a/c off. Do you hear it then? If you want to be sure it stays off just unplug the low pressure switch on the accumulator.
@loxdce
