Trailer Light issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-30-2014, 11:57 AM Thread Starter
Quoted: 11 Post(s)
Trailer Light issue
I bought a new boat the other day and the trailer uses a 5 pin flat connector. I bought a 7round to 5 flat convertor. Tested the trailer lights and everything seemed to work save for one of the side marker lights.
After loading the boat and coming home the lights no longer work at any of the plugs on the truck. The 7round / 5 flat is getting power to the reverse because the surge brake lockout is working. No lights whatsoever on the trailer though. All lights on the truck work fine. Trailer lights work on a different truck.
Ifound a blown 20a fuse in the slot labeled for trailer lights under the dash on the drivers side. I can not find any additional blown fuses. After replacing the fuse there was no change to the function of the trailer lights.
Any suggestions on where to start? I read there is a trailer related relay under hood, is this replaceable?
2005 6.0 F-250 - Upgraded FICM by FICMRepair.com - 4" MBRP Exhaust - PMM Coolant Filtration System - Zoodad Mod - CCV Mod - Blue Spring Upgrade - Updated turbo feed and drain lines - STC update - Updated Standpipes and dummy plugs - IPR Gen2 EGR Delete - PHP 100HP Performance tune -
Chris4x4gill2 is offline
post #2 of 3 Old 06-30-2014, 12:28 PM
All-Right Hauling & Trans
TurboMustang370's Avatar
Quoted: 13 Post(s)
Check under the hood. I believe the '05 and up trucks have an additional under-hood fuse/relay box.
2004 Ford F-350 XLT Dually: crew cab, 8' box, Sinister Mfg. EGR delete, NUC/Amsoil by-pass oil filter, DC Power 185 w/ FICM Repair's full wiring kit, Diamond Eye exhaust, Techni-Cooler, SCT/Gearheads tuning, Edge Insight CTS w/ EAS EGT & FP, Tekonsha Prodigy P3, Line-X and B&W turnover gooseneck.
TurboMustang370 is offline
post #3 of 3 Old 06-30-2014, 01:57 PM Thread Starter
Quoted: 11 Post(s)
Anyone have an idea what size / type fuse would be under the hood. Truck is currently an hour away and there aren't any local parts stores.
