Audio: barney style? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-29-2014, 08:06 AM Thread Starter
RJWTX's Avatar
ok i know apsolutly jack sh!t about audio, what sounds the best, whats needed and not needed, so on and so forth. I've done some research and have come to te conclusion on a single din Alpine w/ bluetooth and Ipod stuff, 5 1/4 Alpine component speakers in the front, one shallow mount rockford fosgate in the back with a boss 1100 for the amp and set the remote switch for the sub on one of my unused upfitter swtiches to turn it off when i dont want it.
how is that set up? im trying to keep it pretty cheap i dont listen to things too loud anymore, and will the front speaker work in the back too or just get 2 way speakers for the back? like i said idk much and have search but have came up with nothing current answer wise. thanks
2006 F350 CC LWB DRW 4x4 auto, AFE cold air intake, Sinister intake elbow, SCT live wire w/ gearhead tunes, 33s, ranch hands front and rear, Pyrometer, Sinister Regulated return, external oil and coolant finter, black diamond headgaskets, ARP studs, update kit, EGR delete, Diamond eye 4" turbo back to duals straight pipe w/ 6" tips, Air Dog 150gph, Topgun Customz 2" leveling kit, 175/stock sticks, KC 2 Turbo, 7.3 fan clutch conversion, Swamps 58v FICM w/ PHP eco tune... more to come
RJWTX is offline
post #2 of 3 Old 06-30-2014, 07:12 AM
scparrish's Avatar
Quoted: 76 Post(s)
Feedback Score: 3 reviews
go with 6x8 speakers, or if you want the polk audio db 6.5 speakers are probably one of the best bang for your buck speakers out there, they go for 60 bucks a set or so on ebay.
Dont' buy boss anything. For a budget amp look at soundstream or ppi, check out onlinecarstereo.com.
Where are you mounting the sub? For a shallow mount I recommend the Sundown Audio SD-2 10, get a dual 2 ohm voice coil version. I recommend sundown because they are built like tanks and come with a 2 year warranty.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #3 of 3 Old 06-30-2014, 07:39 AM
ZMANN's Avatar
Quoted: 1334 Post(s)
a double din would look a lot better and fit better IMHO
up fitter for an Amp remote is a waste of a switch IMHO since the upfitter comes on and off with the ignition i would think it would be smarter to use the Head units REM lead
We Miss you Ronnie
ZMANN is offline
