Adding King Ranch Lighted Running Boards - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-28-2014, 07:59 PM Thread Starter
1NastySS's Avatar
Quoted: 6 Post(s)
I found a set of the KR lighted boards and Ive heard some Lariat trucks had the wiring for these capped off on the frame.Of course mine didn't.I will not hack up wiring to install anything and was wondering If I can just buy the section of harness that the King Ranch would have had,and swap it with mine?
1NastySS is offline
post #2 of 15 Old 06-28-2014, 08:04 PM
ZMANN's Avatar
Quoted: 1455 Post(s)
hit up sunrise the Ford dealer sponsor on this site
it has to be plug and play
did the boards come with the bulbs and sockets ?
We Miss you Ronnie
ZMANN is offline
post #3 of 15 Old 06-28-2014, 08:19 PM
trophy_23's Avatar
Would that not require replacing the whole harness that runs along the frame to the back of the truck?
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #4 of 15 Old 06-29-2014, 05:18 AM Thread Starter
1NastySS's Avatar
Quoted: 6 Post(s)
I hit up Sunrise at least once a week,I wanted to see if anyone has done this before.Luckily the boards were complete.
Trophy,from what I can tell the harness is in sections.Im thinking I can use #14408 in place of what Ive got there now.
1NastySS is offline
post #5 of 15 Old 06-29-2014, 07:53 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
You probably already know this, but you didn't mention, the wire for the lights for the running board is black/light blue tracer.
And, it plugs into the harness at the frame. Looking at the diagram you have posted, it looks like that plug is what my RB is plugged into.
At least on my 04 KR.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 15 Old 06-29-2014, 08:08 AM
trophy_23's Avatar
I was going to mention that black/blue wire color but he didn't want to hack into anything. I have also seen some posts saying something about a dedicated purple wire on some trucks for running boards??
It is hard to tell by that diagram where exactly that would plug in? Is it an addition to the factory harness or a replacement section? That would be nice of it were that easy as replacing a small section, I have wanted to do this for a while but was going to go the route of splicing into dome light wire.
High Idle
Duraflaps
Dually ID Bar
post #7 of 15 Old 06-29-2014, 08:16 AM
ZMANN's Avatar
i can look at mine if you need a pic or something ?
We Miss you Ronnie
ZMANN is offline
post #8 of 15 Old 06-29-2014, 04:21 PM Thread Starter
1NastySS's Avatar
Quoted: 6 Post(s)
ZMANN,I appreciate your offer.Could you just look and see if the section of the harness with the rb connector in it,is a small section that maybe can be swapped out?That 14408 part is about $30,so it must only be a small section,Im thinking maybe it just connects one side of the truck to the other .Itd be nice if it was that simple.Any info greatly appreciated,no big rush.
Dan
Update :Just went out and looked,and it seems like the 14405 harness would be the one Id need,it starts by the transfer case and runs to the back of the truck,the 14408 must be the harness that plugs into the other and also runs across the truck.I really wish the Ford parts site would list the whole part number.
1NastySS is offline
post #9 of 15 Old 06-29-2014, 08:36 PM
ZMANN's Avatar
will do
sorry i was gone all day I will see what I can find in the morning
We Miss you Ronnie
ZMANN is offline
post #10 of 15 Old 06-30-2014, 06:23 PM Thread Starter
1NastySS's Avatar
Quoted: 6 Post(s)
No worries,like I said no big rush.Thanks
Dan
1NastySS is offline
