Tracking down electrical short??? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-25-2014, 09:59 AM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
My Excursion keeps blowing fuse #17, exterior lights. It just started happening a few weeks ago on our way home one night. Driving along and my dash went dark. Luckily I did not get pulled over by the police as apparently the tail lights are also not working. Brake lights work but not tail lights.
I've replaced the fuse and it blew again. I have very little experience with electrical issues and saw that someone suggested checking with a volt meter. If the fuse is blown or keeps blowing, how can one check the circuit with the meter? And after I put in a new fuse, how do you check with the meter? Do you have to cut the wires to see if voltage is flowing?
I did find that one of the bulbs for the license plate was blown and the plug was pretty badly corroded. I doubht this is the issue though. Just not sure how to troubleshoot this. I hate electrical issues.
Zak
2011 F250 Lariat CCSB PowerStroke. Bone Stock
Zak77 is offline
post #2 of 18 Old 06-25-2014, 10:08 AM
ZMANN's Avatar
Quoted: 1911 Post(s)
honestly i would pull the taillights and look at the bulbs first
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 18 Old 06-25-2014, 10:14 AM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
That's an easy first start. Thanks for all the help ZMann.
Zak
Zak77 is offline
post #4 of 18 Old 06-25-2014, 10:22 AM
ZMANN's Avatar
it's a start
they shouldn't cause the fuse to pop unless they are on and their is a path to ground from a bulb/or socket issue
another place to peak is the trailer wires even though the same applies as did to the rear lights
i have seen bulbs fail and short so even cab lights are suspect when trouble shooting
after that out comes the testers and the beer
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 18 Old 06-25-2014, 10:33 AM
Heavy_GD's Avatar
Quoted: 1740 Post(s)
Feedback Score: 3 reviews
I think that runs the fogs, door switch, and radio too.
Its not fun but its time to look for the short.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #6 of 18 Old 06-25-2014, 11:28 AM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
On my Excursion, fuse 17 is just the parking, tail and license plate lights as well as the dashboard (gauges, and lights for the radio/hvac). The radio, interior lights, etc all work. It was a bit creepy driving home at 2am when the dash lights went out.
I pulled the tail lights and the bulbs and wires looked good. A TON of sand/junk behind them so I cleaned out the area well. I removed the blown bulb for the license plate and covered the socket with electrical tape as the socket looks like it broke away from the mount. I replaced the fuse and the lights turned on, but I will keep searching for a break somewhere.
Zak
Zak77 is offline
post #7 of 18 Old 06-25-2014, 11:35 AM
ZMANN's Avatar
if you replaced the fuse and the lights came on what are you looking for ?
whats not working ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
Heavy_GD (06-25-2014)
post #8 of 18 Old 06-25-2014, 11:37 AM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
Lights came on, but I'll have to drive it to see if that fuse blows again. I've replaced that fuse a few times already but just found the blown license plate bulb and removed it. We'll see if that keeps the fuse from blowing, but if not I'll have to start tracing the wires. But it's not something I've really done before and have not used my multimeter much.
Zak
Zak77 is offline
post #9 of 18 Old 06-25-2014, 11:40 AM
ZMANN's Avatar
i think it's that socket
fingers crossed
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #10 of 18 Old 06-25-2014, 02:20 PM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
Another fuse blew. Now my two front power ports are not workikg nor my odbii port.
Zak
Zak77 is offline
