Odd HID issue on my 06. H13 bulbs - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-19-2014, 08:15 PM Thread Starter
j.mo's Avatar
Quoted: 1824 Post(s)
I'm having a very odd issue when installing my hid kit on my 06.
It's a morimoto h13 5k kit.
Both ballasts work, both bulbs work. I have narrowed that down.
They just will not work in unison with this truck. I have grabbed a spare set of bulbs that work, but get the same issue.
So, the driver side low beam will work, only if the passenger side is unplugged.
And the passenger side high beam will work, only of driver side is unplugged.
Neither high beam, nor low beam will come on together.
The pins from the harness are plugged into the correct spots on the power harness from the truck.
Any ideas? Anyone had this issue with theirs?
My neighbor drives a Prius.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.mo is offline
post #2 of 5 Old 06-19-2014, 08:42 PM Thread Starter
j.mo's Avatar
Does not matter how many different bulbs, or ballasts I use. They will do absolutely nothing when you turn the lights on and both sides are plugged in at the same time.
No flicker, no noise. Nothing.
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.mo is offline
post #3 of 5 Old 06-20-2014, 06:37 PM
jlmotox's Avatar
My fogs used to do this but with the truck running it was fine only with the engine off they wouldn't work... I ended up getting new ballasts and problem solved.
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
post #4 of 5 Old 06-21-2014, 09:12 PM Thread Starter
j.mo's Avatar
Got her fixed. Threw my morimoto harness on that I had laying in the toolbox. Fixed it right up.
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.mo is offline
post #5 of 5 Old 06-23-2014, 05:38 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
There was a recall on the ignitor in the ballast and there is an updated high beam controller and harness now too. Stuff is way better
MrOneEyedBoh is offline
