Tachometer reading 1000 rpm with Truck OFF - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-10-2014, 05:42 AM Thread Starter
mdkallam130's Avatar
Send a message via AIM to mdkallam130
My tachometer is reading 1000 RPM with truck off. I have attached two pictures showing what it is doing.
The tachometer appears to be working fine as far as moving like it should but its like the starting point is off.
one of the pictures is with the truck off and key out , the other is sitting at a stop light with truck idling.
what could be causing this , any ideas? Is there some way to recalibrate the tachometer if that's what it needs?
2005 F250 6.0
ID:	297721   Click image for larger version
2002 F250 Crew Cab 4x4 7.3
35x12.50x17 on a set of 2005 F250 Wheels
S&B air intake customized
4"turbo back straight pipe with a 5" tip,
gauges
DP TUNER - on its way
wish list.
5"turnout stacks,injectors,bigger turbo, bigger hpop, fass system, Built Transmission
"I'D RATHER BE JUDGED BY 12 THAN CARRIED BY 6"
mdkallam130 is offline
post #2 of 2 Old 06-11-2014, 06:04 PM
jlmotox's Avatar
Mine does the same thing every now and then...05 f250 4x4 lariet...
I forget the two buttons to push but you can reset the guages by pressing two of the buttons at the same "reset & info" ( I think) or any combo you can to get you into the program screen on your dash... You must push the two buttons while turning your key to the "on" position, if done with the correct 2 buttons "sweep guages" will appear on your dash then it's just a matter of pressing one of the three to make it sweep them...once done you can scroll through the menu and see all sorts of info or just turn your key off and everything will return to normal. Sorry I forget everytime I have to do this which buttons to press...I'm pretty sure you can't screw anything up by pressing the wrong button...
Not sure why this happens but usually does it to me during a long trip or if it is really cold out...and usually only once or twice a year...
Good luck!
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
