Power inverter instructions? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-07-2014, 07:05 PM Thread Starter
Nbdt_country's Avatar
Looking to do either a power inverter or compressor and air tank. Tips, tricks, suggestions appreciated.
Nbdt_country is offline
post #2 of 10 Old 06-07-2014, 07:38 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
my first tip is you need an air compressor for air
and an inverter for electronics
LOL J/K
you should decide what you are going to do and what size then do a search for someone who has done the similar install
there are tons of variables and you didn't give us any specifics on the truck
or device you had in mind
We Miss you Ronnie
ZMANN is online now
post #3 of 10 Old 06-07-2014, 07:43 PM Thread Starter
Haha well guess I deserved that. I do a lot of mechanic work for friends/family/co-workers and a lot of the stuff is out in a field where there's no power and I just need a power source. I'm leaning more towards an inverter I think it would be more useful to me. Plus cheaper I believe and easier installation.
post #4 of 10 Old 06-07-2014, 07:56 PM
ZMANN's Avatar
i do a lot of remote work ( general contractor ) I have a small inverter for grinders and battery recharging (cordless tools) but I also use a Honda 2000 for my skilsaw, welder etc
you can get big ole inverters but you might want to add a battery and a big alternator
and then u usually run the truck the whole time so thats why I like the honda
We Miss you Ronnie
ZMANN is online now
post #5 of 10 Old 06-07-2014, 08:01 PM Thread Starter
Yeah I did the high idle mod just for that. I'll mainly be running grinders, reciprocating saws just stuff like that but corded at the moment wife has me on a budget seeing as how a good portion of 9 month deployment savings have went towards this truck bin the past week alone.
post #6 of 10 Old 06-07-2014, 08:07 PM
ZMANN's Avatar
you can get a decent inverter for what your after
I would find the one you want then go from there the physical size and controls will dictate where you can mount it mine is i the bed so i can access the switch and outlet with the tailgate down I also have a roll n lock to keep it all dry
my third battery is in my toolbox (AGM bat) it runs the inverter but auto connects when I start the truck so it can charge
We Miss you Ronnie
ZMANN is online now
post #7 of 10 Old 06-07-2014, 08:09 PM Thread Starter
About what size inverter would you recommend for what I'm looking for? Sorry new to this whole electronic stuff.. I appreciate all the help
post #8 of 10 Old 06-07-2014, 08:18 PM
ZMANN's Avatar
don't be sorry I don't even know what I would recommend
the one I have is a small husky unit i would have to look at the wattage just checked 400 watt
it does drills and grinders fine I have a big sawzall it will run that also but it could be better
but not a skilsaw
the one I run on my boat is the same one available to semi trucks it's 1500 watt
you would probably be good with a simple clamp to battery style if u wanted simple
but it needed monster welding cable for leads I didn't want to deal with that for the truck
We Miss you Ronnie
ZMANN is online now
post #9 of 10 Old 06-07-2014, 08:53 PM Thread Starter
Maybe if I can go in between them to around 800-900ish I think I'll be fine
post #10 of 10 Old 06-07-2014, 08:55 PM Thread Starter
How did you run your third battery?
