F550 Cruse control - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-03-2014, 03:16 PM Thread Starter
jbobrik's Avatar
F550 Cruse control
I purchased a 2007 F550 bucket truck and i need cruse control for it, Ford says it cant be done do to it being a commercial vehicle? The ECU is not burned for cruse control... I want to know if it can be done, nothing special about the truck, its just ur typical 6.0 chassis with a different bed on it.
jbobrik is offline
post #2 of 6 Old 06-03-2014, 03:53 PM
Airborne CIB's Avatar
No need to reprogram the ecu. Just install steering wheel with cruise buttons and a clock spring with cruise wires and the ecu will recognise. I literly just did this last week. 30 minutes and you need a steering wheel puller.
Glendale, AZ
'05 F250 XL Extended Cab - 2 Wheel Drive, No Options Except: Integrated Brake Controller, 3.73 w/ Limited Slip, Upfittter Switches & AC
Added: Edge Monitor with EGT, Fuel Pressure, coolant pressure, low oil pressure system sensor & Ambient Temperature Sensors, turbo timer & back up camera. High Idle Mod. Manual Fan Mod, Power fold/power extend mirrors.
Installed: Cruise Control w/ Leather Steering Wheel, 17 Alloy Rims off XLT, 40 20 40 Vinyl Front Seats
Well maintained with Motorcraft parts, over 222k miles and still have original head bolts.
Airborne CIB is offline
post #3 of 6 Old 06-03-2014, 04:25 PM Thread Starter
jbobrik's Avatar
Nice, so did you just order a factory cruse control setup from Ford? Does all that come with instructions? Were does the clock spring go.
Thanks for your help!!
jbobrik is offline
post #4 of 6 Old 06-03-2014, 04:39 PM
Yes, you can get the OEM kit that does come with steering wheel, clockspring & instructions, but it only comes with the black plastic wheel and I wanted leather. So ordered a NOS leather wheel on ebay and a clock spring for cruise. The clock spring is the ribbon connector behind the steering wheel. Disconnect the batteries 10 minutes to allow the restraints control module (RCM) to de energize before removing airbag.
Glendale, AZ
post #5 of 6 Old 06-03-2014, 04:56 PM Thread Starter
jbobrik's Avatar
10-4 I will order the parts and proceed.. Thanks again
jbobrik is offline
post #6 of 6 Old 06-09-2014, 12:22 PM
kslongrider's Avatar
Quoted: 2 Post(s)
So how did it go? I need to do this one myself!
kslongrider is offline
