Auto locks not working - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-03-2014, 07:44 AM Thread Starter
Powerstroke Tech
whitestrikr21's Avatar
Quoted: 3 Post(s)
Garage
I have an 03 f350 with keyless entry, i looked up the procedure in the owners manual to turn autolocks on/off noting happens when it says the horn should beep. I have tried this numerous times same result. Anyone know if you can go in with ids and change it that way?
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
XDP egr delete
whitestrikr21 is offline
post #2 of 7 Old 06-03-2014, 08:36 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
just to clarify your using the keypad and the factory code not a user code to try and set the auto locks
We Miss you Ronnie
ZMANN is online now
post #3 of 7 Old 06-03-2014, 08:51 AM Thread Starter
Powerstroke Tech
Quoted: 3 Post(s)
Garage
No the manual says to turn the key on hot unlock three times key off unlock three times turn key on should hear the horn chirp ( doesn't chirp) the hit unlock and lock should either chirp or double chirp depending on if auto locks on or off
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
XDP egr delete
post #4 of 7 Old 06-03-2014, 09:08 AM
ZMANN's Avatar
gotcha I thought it could be done on the keypad as well but wanted to see how your were doing it
like this correct
How To Disable AutoLocks
Note: Manual transmission vehicles have this feature disabled at the factory. This procedure applies to most newer Ford vehicles, not just Ford trucks.
The enable/disable mode allows the autolock feature to be turned off and on. On manual transmission vehicles, when replacing the remote anti-theft personality (RAP) module, the autolock feature must be turned off by using the enable/disable mode.
The enable/disable mode is entered when the following series of steps is performed:
1. Confirm that the perimeter alarm is disarmed.
2. Close all doors.
3. Confirm that the ignition switch is in the OFF position.
Note: Steps 4 through 8 must be performed within 30 seconds.
4. Turn the ignition switch from OFF to RUN.
5. Press the power door lock UNLOCK button three times.
6. Turn the ignition switch from RUN to OFF.
7. Press the power door lock UNLOCK button three times.
8. Turn the ignition switch from OFF to RUN.
9. Verify that the RAP module chirps the horn. This indicates that the RAP module is now in the enable/disable mode and ready to accept program changes.
10. Press the power door lock UNLOCK button one time to command the RAP module to toggle the autolock/relock feature ON or OFF.
11. Press the power door lock LOCK button once to enter the command.
12. Verify that the vehicle horn chirps one time to signal the RAP module confirmation of the command. There should only be one chirp indicating that the autolock/relock feature has been disabled. If one chirp is heard, followed by a longer honk, the autolock/relock feature has just been enabled. Return to step 10.
13. Turn the ignition switch to the OFF position to exit the enable/disable mode.
14. Verify that the RAP module chirps the horn once to indicate that a feature has been changed.
The autolock and the appropriate alarm configuration are turned on at the factory on vehicles with automatic transmissions. Vehicles with manual transmissions have the autolock turned off at the factory. The RAP module returns to the prior setting any time battery power is interrupted.
We Miss you Ronnie
ZMANN is online now
post #5 of 7 Old 06-03-2014, 09:24 AM Thread Starter
Powerstroke Tech
Quoted: 3 Post(s)
Garage
Yes that is how I attempted to do it. I don't have the key pad
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
XDP egr delete
post #6 of 7 Old 06-03-2014, 10:07 AM
ZMANN's Avatar
well heck I know it took me a few tries
but it's been a while
I don't know if IDS can do it ??
We Miss you Ronnie
ZMANN is online now
post #7 of 7 Old 06-03-2014, 02:34 PM Thread Starter
Powerstroke Tech
Quoted: 3 Post(s)
Garage
Ok I guess I have to keep trying
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
XDP egr delete
