Electrical gurus I need some relay insight - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Rammstein1224
post #1 of 6 Old 06-02-2014, 06:28 PM Thread Starter
IamMonsterMan's Avatar
I want to wire something that stays on as soon as the key is on/engine running, but I want it to shut off when I turn the headlights on. I'm sure I can do this with relays but I'm kind of having a brain fart on how to go about it. Any help?
'04 F-350 6.0 4x4 Reg. Cab Long Bed (SOLD)
Billet Torque Converter || EGR Delete || Airaid Intake || Catless & Mufflerless || 4" Downpipe || 5" Sidepipe w/ 6" Tip || SCT X4 || 35" Hankook Dynapro MT's on 16" Ion's || XDP Coolant Filter || Kenwood Head Unit || 2014 Tailgate
IamMonsterMan is offline
post #2 of 6 Old 06-02-2014, 06:51 PM
ZMANN's Avatar
Quoted: 1357 Post(s)
what if we leave the KOER out of the equation just because IDK what the headlights can do with the key off on your truck ?
and just say you want the device to go off with the headlights ?
you would use the headlight power to activate a relay coil and break ground
use a 5 pin relay like the easy to find units with the 87 and 87a
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 06-02-2014, 06:59 PM
ZMANN's Avatar
85 to ground
86 to your headlight power from switch
30 and 87a is normally closed so use this for a pass through either + or - to your device
when the coil 85 and 86 receives power it will break the circuit 30 and 87a
you would just need to find a KOER positive lead for the device and depending on the amp load yo may need another relay to isolate it
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 06-02-2014, 07:52 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
This is a diagram of the "safest" way to wire it. Theres other ways but this would be the best
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 6 Old 06-02-2014, 07:59 PM
Chapter Director
Quoted: 5 Post(s)
Pic didnt post
dfuzz78 likes this.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 6 Old 06-02-2014, 08:29 PM Thread Starter
Thanks for the quick replies guys! I appreciate the help
