Wires to nowhere - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-02-2014, 01:24 PM Thread Starter
Airborne CIB's Avatar
Wires to nowhere
What are these wires for? They look factory spliced, but they could be anything, I bought it used.
Glendale, AZ
'05 F250 XL Extended Cab - 2 Wheel Drive, No Options Except: Integrated Brake Controller, 3.73 w/ Limited Slip, Upfittter Switches & AC
Added: Edge Monitor with EGT, Fuel Pressure, coolant pressure, low oil pressure system sensor & Ambient Temperature Sensors, turbo timer & back up camera. High Idle Mod. Manual Fan Mod, Power fold/power extend mirrors.
Installed: Cruise Control w/ Leather Steering Wheel, 17 Alloy Rims off XLT, 40 20 40 Vinyl Front Seats
Well maintained with Motorcraft parts, over 222k miles and still have original head bolts.
Airborne CIB is offline
post #2 of 7 Old 06-02-2014, 01:29 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im at work so I cant see pictures but Im gonna bet you are talking about the wires just below the cowl on the drivers side.. if so dont sweat it . Ford actually thought ahead and put those to the upfitter switchs to make it easier to run extra goodies. Its all good nobody has hacked your wires.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Airborne CIB (06-02-2014)
post #3 of 7 Old 06-02-2014, 01:32 PM Thread Starter
Yep, Just below the cowl on the drivers side. Thanks!
Glendale, AZ
post #4 of 7 Old 06-02-2014, 01:36 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
No sweat brother. WELCOME TO THE SITE!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 7 Old 06-02-2014, 02:01 PM
ZMANN's Avatar
Quoted: 1651 Post(s)
they actually aren't to the up fitters they are blunt spliced on both sides of the firewall for you to use for whatever u want up fitters or not
customer access wires
We Miss you Ronnie
ZMANN is offline
post #6 of 7 Old 06-02-2014, 05:41 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^Yup your right. I got to thinking more about this and was gonna correct myself but you beat me to it!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 7 Old 06-02-2014, 05:44 PM
ZMANN's Avatar
i know where your coming from because it's in the Ford up fitters info guides/pdf's
so it gets confused for up fitter switch wires a lot
We Miss you Ronnie
ZMANN is offline
