Best LED tail light bulbs - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By dfuzz78
post #1 of 7 Old 06-01-2014, 06:56 PM Thread Starter
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'm gonna be receiving a set of stock 05-07 tail lights, (thanks Merc82) probably this week. I'm planning on cleaning them up and having them sprayed with a custom tinted clear coat and I want to know what the best and brightest LED bulbs I can get for them. Wouldn't mind switching to a good and bright set for my 05+ HD head lights. Any input is appreciated.
dhanna6powerstroke is offline
post #2 of 7 Old 06-02-2014, 05:52 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Retro-Solutions has the absolutely brightest LED bulbs out there!
http://retro-solutions.net/product-i...bs-pid896.html
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 7 Old 06-02-2014, 07:39 AM
F3502wd's Avatar
Feedback Score: 3 reviews
3156 3157 3057 3047 4157 T20 LED Super Wedge Bulbs - Retro-Solutions Store
Where do you have those bulbs mounted and how do you like them compared to stock
F3502wd is offline
post #4 of 7 Old 06-02-2014, 07:41 AM
dfuzz78's Avatar
Tail lights.
There is no comparison to the stock bulbs!
Denis "Lt. Sled"
dfuzz78 is offline
post #5 of 7 Old 06-02-2014, 07:43 AM
Heavy_GD's Avatar
Quoted: 1557 Post(s)
mounted? they go in the factory socket... short of an LED taillight the "tower" style bulb is the best option unless you step up to something like this:
RED V3 TRITON LED SYSTEM | 1 PAIR
But at that point just get an LED taillight.
GD
Heavy_GD is offline
post #6 of 7 Old 06-02-2014, 07:45 AM
dfuzz78's Avatar
Also, do not use resistors for the LEDs!
Get an EP27 flasher and just replace the flasher.
It's behind the drivers glovebox, hidden by some while fabric.
Heavy_GD likes this.
Denis "Lt. Sled"
dfuzz78 is offline
post #7 of 7 Old 06-03-2014, 10:39 AM
Retired Army
superbrightleds.com
I used some LEDs from superbrightleds.com and have been pretty happy with them. I mistakenly got the CANBUS lights and they burned out fairly quickly (maybe 2 months or so) but my 2nd set have lasted almost a year now. I have the tower style bulb replacement and stock housings. The backup lights were already LED when I got the truck and I now have the tail lights, high mounted third brake light, and the backup lights. I did change my flasher unit as well. Still need to order LEDs for the front turn signal (looks like the factory fogs have LEDs in them already - another gift from the PO).
2004 F250 SRW FX4 Lariat CC LB
Sinister delete, XDP coolant filter, NUC oil bypass, fumoto valves, AFE stock replacement, Riffraff boots, Ultra ELC, CTS and Glowshift gauges, SRL, Wicked Wheel
08 trans pan/filter, 08 diff cover, Racor CCV6000
ranger51r is offline
