Sat Radio Power Hook-Up - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-30-2014, 02:53 AM Thread Starter
Hello all
Trying to hook up a direct power connection for my Sat radio (red and black wires) Ground not a problem, but would like to hook it up the red wire to a power source that turns off with the ignition switch like I've done in other cars
Tried tapping into the radio fuses in the fuse box but one is always hot the other is only 5v and doesn't help
Don't like that the cig lighter / power sources are constantly hot and don't turn off with the ignition switch either
Any ideas?
Cosman is offline
post #2 of 4 Old 06-02-2014, 05:54 PM
USAFBowman's Avatar
Why not hook it to the remote wire coming off of the radio itself that way when the radio is on the satellite receiver will power on as well and when the radio is off then the satellite receiver is also off.
USAFBowman is offline
post #3 of 4 Old 06-02-2014, 07:05 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
I would find a fuse that is hot with the key on and off when the key is off. Its easy to find with a test light. Then install one of these. Its a add a circuit. It replaces the fuse and has fuses for the fuse you replaced and an added circuit. Be sure to pull the fuse and test to see what side has power. Which ever side has power put the lead on the other side.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 4 Old 06-02-2014, 07:19 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
agreed use a retained power lead like the one to the radio
We Miss you Ronnie
ZMANN is online now
