What all conditions will trigger the battery light? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 16 Old 05-09-2014, 11:16 AM Thread Starter
hossrod's Avatar
Quoted: 6 Post(s)
Question What all conditions will trigger the battery light?
I had a bad alternator and the light never came on (would be in the 11.8-12.1v even on freeway, sometimes getting to 12.8-13.1 randomly). I just put a new one on, and the light is now coming on randomly, even though my CTS shows great stable voltage 13.8-14.1v at the time. Sometimes it comes on and stays solid for several seconds, other times it's quick random flashes, sometimes kind of flickers randomly. I see no other issues of ill effects. Everything electric seems great, no light pulsing/dimming with rpm, batteries maintain better charge and engine cranks quicker when starting, etc.
So I'm wondering, what all conditions can cause the battery light to come on?
I had both batteries tested separately at the time of getting new alternator, and they were good.
2005 F250 CC/SB
hossrod is offline
post #2 of 16 Old 05-12-2014, 06:48 PM Thread Starter
hossrod's Avatar
Quoted: 6 Post(s)
No one?
Under warranty, I swapped out the new alternator for another one and been a couple days and so far battery light hasn't come on even once. So guessing first one was bad, even though it tested fine both in the truck and on the bench tester.
But still wondering what all can cause the battery light to trigger. I take it that its more than just low voltage. I'm wondering if other alternator would sometimes not charge enough, so voltage stayed good, but technically there was a drain rather than a charge. Like if I had one of those old school ammeter that showed positive and negative flow, it would be on slight negative.
2005 F250 CC/SB
hossrod is offline
post #3 of 16 Old 05-12-2014, 07:38 PM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
I think it's triggered by ignition position and low voltage. What pid are you monitoring voltage with?
Sent from one of the worst apps in the world
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #4 of 16 Old 05-13-2014, 06:26 AM Thread Starter
hossrod's Avatar
Quoted: 6 Post(s)
I'm not sure of pid number, but the insight calls it battery voltage.
Ignition position is in the run position. It did it while the engine is running and driving around.
I plan to install a dedicated in dash LCD volt meter soon that will be directly connected to the battery clamps. This will allow me to monitor battery voltage at anytime (off, cranking, running, etc), and free up a pid gauge on the insight.
2005 F250 CC/SB
hossrod is offline
post #5 of 16 Old 05-13-2014, 07:49 AM
Quoted: 408 Post(s)
Garage
my torque has ficm logic power and battery voltage. I wasn't sure which you were using.
post #6 of 16 Old 05-13-2014, 08:20 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
A bad alternator can put out 13+ volts but the amperage is very/too low, this is usually a sign of a bad regulator and will intermittently flash the battery light.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
The Following 2 Users Say Thank You to Qholic For This Useful Post:
hossrod (05-14-2014), Teachagmech (05-13-2014)
post #7 of 16 Old 05-18-2014, 10:13 PM
Having the same issue with my 06.
Gnwdad is offline
post #8 of 16 Old 05-19-2014, 06:16 AM Thread Starter
hossrod's Avatar
Quoted: 6 Post(s)
I ended up taking my "new" alternator back. I had them bench test it again, and still passed. I asked to swap it out for another one anyways and they didn't have issue with that and gave me another one off the shelf (note, same brand/model/etc).
Been a week and haven't had a single issue. Battery light hasn't come on even once (while running, it comes on with ignition so I know bulb is good).
So I think the issue is that it's voltage was fine, but wasn't outputting enough current. This is inline with what Qholic said about the light also coming on for current.
This also means I no longer have any confidence in the auto stores testing.
The good news is, I can now swap out an alternator in about a minute.
2005 F250 CC/SB
hossrod is offline
post #9 of 16 Old 05-19-2014, 07:10 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Glad to hear your back up and running, I too had the same issue they checked the alternator and said it was good, changed alternator out and all is well. This truck has got to be the easiest alternator I've ever changed out...
Shawn
post #10 of 16 Old 05-19-2014, 07:44 AM Thread Starter
hossrod's Avatar
Quoted: 6 Post(s)
Originally Posted by Qholic View Post
... This truck has got to be the easiest alternator I've ever changed out...
Once I figured out to use a long handled 1/2" ratchet on the tensioner, it was butter. My serpentine belt tool wouldn't fit.
When I took the alternator back to test/swap, I changed it in the parking lot.
2005 F250 CC/SB
hossrod is offline
