Voltage loss checking - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-05-2014, 10:03 PM Thread Starter
How do you check for a voltage drain with a multi meter using the two grounds from the batteries? Do you disconnect both then test with one or do you you just test it with one of the grounds removed? What is an acceptable drain?
Many thanks in advance for the help.
69hemi is offline
post #2 of 3 Old 05-22-2014, 04:39 AM
Buford Pusser's Avatar
good question..... ANYONE?
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.
-Winston Churchill
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist!!
Buford Pusser is offline
post #3 of 3 Old 05-28-2014, 07:58 PM Thread Starter
Figured it out that you need to disconnect both and bridge one with the meter. BTW it was the gauge cluster causing the draw.
69hemi is offline
