Fuel guage stuck on full - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-25-2014, 04:54 PM Thread Starter
dhetrick2's Avatar
Ok, I have searched and read just about every post about this and most of them old. I have an aux fuel tank with gravity drain and have been using it for several years now with no problems. The other day I filled the main tank with the truck shut-off like I always do and turned the aux tank off. After I drove for over one hundred miles the guage still showed full and I got a P0460 code which has something to do with the fuel sender. I cleared the code but the fuel guage is still stuck on full. Hoping for any ideas other than dropping the tank. thanks
2006 F350 6.0 SRW King Ranch CC 4x4
MBRP 4" turbo back w/cat
Edge Insight CTS w/expandable EGT
Fomoto drain
Zodad mod
ARP Head Studs
Sinister Coolant Filter
Atlas 40 by PHP
$25 CCV mod
Motorcraft Premium Gold
dhetrick2 is offline
post #2 of 2 Old 05-03-2014, 06:39 PM
AaronB.F250's Avatar
Quoted: 2 Post(s)
I just replaced my fuel sender 2 months ago. I was fueling my truck with it running and when I started it next morning check engine light came on. code came up as fuel sender. me and my brother inlaw dropped the tank and changed it out had the truck up in running in 2 hours. just make sure the tank is close to empty, 38 gallons can be heavy.
2006 CCLB Lariat 6.0
4"D.P 5" straight pipe. APR studs. EGR delete. H&S mini maxx. Dummy plugs. Stand pipes. LED interior, Reverse lights, 6K Fogs. High Idle mod. Daily Driver
2009 F-450xlt 6spd 6.4
9' enclosed utility body. Work Truck
AaronB.F250 is offline
