Digital Voltmeter Mod - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By kinnisoj
post #1 of 10 Old 04-15-2014, 04:50 AM Thread Starter
Speed_Bump's Avatar
So, I recently had to replace my FICM, and think that it may have been due to low battery voltage. I have Torque, but sometimes it a pain to start the phone, then the app, then wait for Torque to load just to see the volts when starting. So, I found this little digital voltmeter on Amazon, and decided to give it a try. I like how it turned out. Haven't seen it at night, so I hope its not to bright.
I found a wire (yellow\white stripe) in the ignition that only comes on when the key is turned to run. It also doesn't shut off during cranking, which other wires I tried did. The black wire was just grounded to a nearby ground.
2004 PowerStroke 6.0 CC (Early Year) 150,000 mi.
Mostly stock other than Blue Spring, Studs, EGR Delete, Coolant Filter, High Idle Mod
Speed_Bump is offline
post #2 of 10 Old 04-17-2014, 05:50 PM
Looks good, I did a similar install but I mounted the unit in the half cubby hole beside my upfitter switches. I got the voltage from a wire that is left dead headed to power after market gauges, however it cuts out during cranking, I like your source better.
Phil
2005 F350, 6spd, arp studs, banks big hoss bundle, straight pipe with dual exhaust, egr delete, high idle mod, dashboss monitor, battery tender 800ma, 6.5 watt solar panel, kn cold air intake with an s&b filter, dfuser coolant filter, bds 4" lift on 325/65/18 bfg all terrains
phil_phil is offline
post #3 of 10 Old 04-17-2014, 06:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Very cool! I have not seen anybody else come up with this idea. Nice!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 10 Old 04-17-2014, 06:47 PM
ZMANN's Avatar
Quoted: 1789 Post(s)
A digital voltmeter ?
We Miss you Ronnie
ZMANN is offline
post #5 of 10 Old 04-17-2014, 06:49 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
I'm diggin it man. I like it.
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
post #6 of 10 Old 04-17-2014, 06:55 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Not set up like he has it you ball buster!
Speed_Bump likes this.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 10 Old 04-17-2014, 07:07 PM
ZMANN's Avatar
not bustin balls I just thought this was common
if the CTS didn't read battery voltage and FICM voltage while cranking I would have one but with the AMPS option
also it's nice to know they sell a cig lighter version and the OEM power port stays on during cranking
the install is nice and clean on the OP's truck I think the red LED might be a bit much if it's not dim able
We Miss you Ronnie
ZMANN is offline
post #8 of 10 Old 04-18-2014, 08:33 AM
Term3's Avatar
Quoted: 2 Post(s)
I think it would be more interesting to have it tapped directly into the FICM. Seen it done on a couple trucks.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #9 of 10 Old 04-19-2014, 03:51 PM
XL trash...
Merc82's Avatar
Quoted: 323 Post(s)
I like it!! Very clean, Amazon link?
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #10 of 10 Old 04-19-2014, 06:37 PM Thread Starter
Speed_Bump's Avatar
http://www.amazon.com/gp/product/B00B689UGA/ref=oh_details_o01_s01_i00?ie=UTF8&psc=1
I got green to match the interior lights. They make them in other colors too.
Tags
digital , mod , voltmeter
