Sunroof motor operates only 1 direction - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-11-2014, 02:43 PM Thread Starter
Quoted: 3 Post(s)
Working on a 2006 f250 king ranch. I thought I had this issue tracked down to it being a faulty relay on the sunroof's motor circuit board. So since it's not serviceable, I bought a new motor, resulting in same exact symptoms.
The motor only operates in the open direction; The close direction, nothing at all. The switch changes polarity properly both directions at the motor pig tail, so switch is fine. I jumped a negative wire from battery to the open wire, operates; but when I jump to the close wire, nothing at all.
Am I missing something here? I'm assuming there is another wire that controls the operation, its unlikely they sent me motor with same problem.
If someone has a wiring diagram, it would be greatly appreciated!
TamedZ is offline
post #2 of 7 Old 04-12-2014, 07:36 AM Thread Starter
Quoted: 3 Post(s)
Wiring diagram anyone for the sunroof anyone?
TamedZ is offline
post #3 of 7 Old 04-12-2014, 09:17 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
What I found on alldata
Please
You could save the life of a sick child
NYC F-350 is offline
The Following User Says Thank You to NYC F-350 For This Useful Post:
TamedZ (04-12-2014)
post #4 of 7 Old 04-15-2014, 06:41 AM Thread Starter
Quoted: 3 Post(s)
Well I am stumped. The wiring seems good. It acts like it needs to be initialized as the instructions say it will only operate in the open direction until it is. I have tried the procedure both the old and new motor. I can manually crank the glass to full tilt, press the open button and it goes all the way to full open with out making any stops or moving forward like it's supposed to. It seems like it won't initialize.
Any ideas anyone?
Thanks again for sending the wiring NYC
TamedZ is offline
post #5 of 7 Old 04-16-2014, 06:13 AM Thread Starter
Quoted: 3 Post(s)
No one has any experience with these things?
TamedZ is offline
post #6 of 7 Old 06-20-2014, 02:09 PM
you have to initiate the new motor process. Search it on google. Any time you take it apart or replace the motor you need to do it. You like hit the open button until it goes back, then hit it again, then release, then hit it again and I closes, tilts, and closes. Im having issues right now, something broke in my sunroof today so im trying to figure out to fix it. Ran across those directions earlier and your thread just now
08 Black CC/SB lariat, billet grill inserts, Toyo 35X12.5R20 open country m/t, Newton lift 2.5" front with 5" blocks
Spartan 275, 5" downpipe back SS w/ 18"x6" tip, AFE Stage 2 PG7
4" custom downpipe being made
madman1234509 is offline
post #7 of 7 Old 06-21-2014, 03:53 AM
Snake's Avatar
Quoted: 46 Post(s)
I had the same problems with my moon roof and had to replace the entire assembly.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
