Radio question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2014, 09:18 AM Thread Starter
BBsBlueOval's Avatar
Radio question
Ok I've got a jvc double din. After having my batts disconnected last night my radio has no sound out put. Lights up and acts as normal but no sound?? What could it be
Livin the Lake Life
BBsBlueOval is offline
post #2 of 3 Old 04-09-2014, 09:25 AM
TwinTurbo6.4's Avatar
Quoted: 82 Post(s)
I would start pulling fuses. Not to sure what fuse it is on the 6.0's, but i had a similar issue on mine when installing my new Head Unit.
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #3 of 3 Old 04-10-2014, 11:47 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 551 Post(s)
Garage
You may try powering down the stereo again. Totally drop power to it, there is often two power feeds to the head unit make sure both fuses are intact. Stereo's will go through safety tests when they power on and off. If it takes longer to power up or down there is a reason for it. There is a sequence that they go through and if something is grounding or crossed up possibly.
So:
Check all fuses
Drop power 100% ( disconnect battery again if needed)
Reconnect power and cross your fingers.
Check bypasses if equipped. (Video bypass gadgets)
Good Luck with it
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
