Running power lead from back to upfitter leads in engine compartment. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-07-2014, 03:00 PM Thread Starter
Quoted: 5 Post(s)
Running a lead from a set of rear LEDs to an upfitter switch. What's the best routing option to get the lead into the engine compartment?
Thanks in advance.
'07 CC/SB FX4
XDP Coolant Filter
Blue Spring Mod
High Idle
4" Turbo Back Exhaust
200* Mishimoto T-Stat
EGR Delete
Leveling Kit
Billstein 5100s
Pro Comp Dual Steering Stabilizer
P7M8 is offline
post #2 of 4 Old 04-07-2014, 03:20 PM
MUDSLTOR's Avatar
There is a harness already running from the engine bay to the rear of your truck along the driver's side frame rail. Just follow the path it took to get there. That is what I did when I put in my LED reverse lamps. As a side note to help you that I did not think of until a week or two after I completed my install was that I ran straight from my upfitter to the lights. I am going back and putting a connector in at the break between the cab and the bed so if I ever need to lift the cab I just need to undo the connector and then at the rear so if I ever need to pull the bumper I just disconnect at that connector as well. Best of luck to you.
'05 6.0L PSD CC Purchased on 4/22/13
Need to really get a good look in the engine compartment to see what all has been done for sure.
4" Turbo back exhaust 6" Fab Tech Lift w/ dual steering Stabalizers 35" tires 92K miles
I promise to update as much as I can with my limited knowledge of the PSD and add some pics too.
MUDSLTOR is offline
post #3 of 4 Old 04-07-2014, 03:28 PM Thread Starter
Quoted: 5 Post(s)
Thanks for the reply. Where did you ground the lights?
'07 CC/SB FX4
XDP Coolant Filter
Blue Spring Mod
High Idle
EGR Delete
Leveling Kit
Billstein 5100s
P7M8 is offline
post #4 of 4 Old 04-07-2014, 04:17 PM
MUDSLTOR's Avatar
If I remember correctly I loosened a bolt holding my trailer outlet to the frame and connected the ground there as it was close to the first light. I installed a pair of 7inch LED fog/work lights. They work great.
MUDSLTOR is offline
