Added theft protection - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-07-2014, 04:27 AM Thread Starter
USAFBowman's Avatar
Hey guys,
Been a long time since I've been on the forums and have done a lot of catching up. It sucks being 6000mi away from your truck while deployed and are not even able to enjoy it. Getting on the forums just made me sad and miss my truck even more. But I will be back home shortly.
I've been looking at adding to my anti-theft set up I already have in my truck. I have a hidden kill switch as well as a Compustar Alarm/Remote start. The model number of the exact Compustar brain escapes me but I have been looking for the ones that my remote works with and they all appear to be the same sort of set up. I am looking to add a kill-relay to my wonderful mess of anti-theft. My only concern is that the description of the wire I want to tap into to activate a relay that cuts the ability to start the truck when the alarm is active says this "250mA negative (-) output when armed and during remote start (while running). This wire is pre-wired to the anti-grind/starter-kill relay. Caution: When this wire is being used to trigger aftermarket accessories it must be diode isolated."
I am no electrical genius in anyway, so thus I ask you for help. I am assuming since I am using this to be the activated ground for my relay to kill the trucks starting system I can not just tap directly into the wire and would have to use a diode to accomplish this or is there one in the relay as pictured as my "wiring diagram"? Will the fact that it gets powered when remote started totally throw off this whole plan and will I just end up shootin myself in the foot?
"Wiring diagram" for the relay
Thanks guys. I appreciated your electrical knowledge.
USAFBowman is offline
post #2 of 5 Old 04-07-2014, 04:49 AM
shenanigans
junior125's Avatar
Quoted: 1506 Post(s)
Garage
The python alarm remote start had a starter kill wired into, One of the eyes came loose on me and I couldn't use the key to start it
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #3 of 5 Old 04-07-2014, 04:50 AM Thread Starter
USAFBowman's Avatar
I already have my compustar though and have no problems with it. I'm not looking to replace it. I'm just looking to add another piece to my anti-theft puzzle
post #4 of 5 Old 04-07-2014, 06:15 AM
shenanigans
junior125's Avatar
Garage
some alarm remote starts have a starter kill built into them, if it doesn't I don't see an issue adding this to your current setup
Mike
2005 CCSB F250 4X4
post #5 of 5 Old 04-08-2014, 03:03 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
The only issue I have is the Relay high enough current wise. The starter draws a lot of amps
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
