Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 12-08-2006, 06:30 AM
Logan Logan is offline
The Fat Mod
Upfitter Switches
OK, any one know if you can get a set of upfitter switches for a 2004? If so, where. Thanks for the help in advance.
Old 12-08-2006, 06:44 AM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
I'd say go to the dealer. They are between $90-$110, I believe. And you should be able to hook it up, I think it just needs power to it, and then the switches will work. The only thing is, you'll probably have to either modify your dash to make a cuppy hole for it, or just mount it under it. But it should work, at least that's what I was told by my srvc dept, when I was first searching for my truck, I found several in the config that I wanted that didn't come w/ the switches, and they said it was simple to put them in.
-BG06.
Old 12-08-2006, 06:48 AM
The Fat Mod
Thx BG06, I was wondering if you could maybe put them in the little hole we all have in the dash kinda under the 4x4 switch. would have to drill the back, but it would be hidden in the end.
Old 12-08-2006, 06:50 AM
I'm not sure, if you want I'll try to see if I can get the measurements for you.
-BG06.
Old 12-08-2006, 06:53 AM
The Fat Mod
Do you have the switches, if you do, that would be awsome. I just want to have a bunch of stuff in it and be as factory as it can be. If ya know what I mean.
Old 12-08-2006, 07:29 AM
Yeah I was lucky enough to get the config I wanted w/ the upfitter switches. I'll check the measurements and get them to you by 1200.
-BG06.
Old 12-08-2006, 07:30 AM
The Fat Mod
Ok, no hurry, but thx again.
Old 12-08-2006, 06:33 PM
davidwruth davidwruth is offline
I read a post on another forum that guy did it on his 04 250. He said that there was a plug on his fuse panel that allowed him to do it and he said that he drilled four small holes for the upfitte switch tabs. He also put a piece of Lexan in the rest of the hole. He had pictures it looked pretty good
Old 12-11-2006, 05:18 AM
I finally had some time to get those measurements. The switchesare 4"L x 2"H. I don't know the depth though. I'd say if you were going to make a whole do it a little bigger than those figures.
-BG06.
