Best subs for 04 f250 crew cab? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-24-2014, 05:25 AM Thread Starter
What are the best shallow mount subs for behind for the seat of a 04 f250?
I am looking at jls, but I don't know which ones to get....I know I want shallow mounts. I am thinking of getting 3 12" subs, and a truck box to put behind the seat.
Just want someone to point in the right direction on how they would work like that.
case123 is offline
post #2 of 15 Old 03-24-2014, 06:30 PM
What kinda music you listen to?
YFZ_53 is offline
post #3 of 15 Old 03-24-2014, 07:05 PM
jluv's Avatar
Quoted: 13 Post(s)
JL makes a 13tw5, but you're not gonna get 3 of them, or likely even 2 of them behind the seat with the right amount of air space.
They also make a 12" tw3, but it's not as shallow as the w5 and will have less output/power handling. Again, good luck getting 3 of them back there with the right amount of air space. I suppose it's possible if you run sealed, but there again, you sacrifice output.
JL makes a stealth box with one ported 13tw5 that fits perfectly under the rear seat. It's "okay" output, but not near enough for me, personally. I had a custom ported enclosure made to replace my entire center console/jump seat and it houses a ported Type R 15.
jluv is offline
post #4 of 15 Old 03-24-2014, 07:16 PM
Pro fuzz's Avatar
Quoted: 29 Post(s)
I'm running a jl audio 13 w5 in ported box behind driver side rear seat on a 500x1 amp sounds great for the limited space in these trucks !!!
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is offline
post #5 of 15 Old 03-24-2014, 07:26 PM
Pro fuzz's Avatar
Quoted: 29 Post(s)
The box is from spl2k .com
s:
Pro fuzz is offline
post #6 of 15 Old 03-25-2014, 03:36 AM Thread Starter
Well...from sonic electronix I found a box made for 3 shallow mount subs, that fits right behind the rear seat. The box is 75$. And he said he will give me 3 12" kicker shallow mount subs for 120$ each, or 3 rockford and fosgate shallow mount subs for 60$ each.
I'm thinking if I get that box, and 3 12" kickers, I should be hittin kinda hard right?
I listen to everything really. But mainly country/r&b/rap
case123 is offline
post #7 of 15 Old 03-25-2014, 03:56 AM
jluv's Avatar
Quoted: 13 Post(s)
It's all relative, but that wouldn't hit all that hard compared to a traditional enclosure with a full sized sub and plenty of power. But it may be enough for your taste. Check the specs on each sub for air space requirements and compare that to the box. Remember to subtract the displacement of the subs when figuring the volume of the box. It may sound alright. Just don't make the mistake of cramming any sub into any box. It isn't that simple.
jluv is offline
post #8 of 15 Old 03-25-2014, 12:26 PM
HotZone's Avatar
Do u have any pic of your setup.
Thanks
2004 F250 SD CC
Hpop Delete
EGR Delete
ZooDad MOD
Upgraded Turbo
Upgraded Inj
4" Turbo Back Exhaust
SCT TSX Programmer
Viper Alarm W/ Remote Start
15K HID Headlights
15K HID Foglights
UPDATE... ALL DECALS REMOVED GOING FOR SOMETHING DIFFEREN>>>POST WHEN DONE...
HotZone is offline
post #9 of 15 Old 03-25-2014, 01:06 PM
Pro fuzz's Avatar
Quoted: 29 Post(s)
Sorry no pics u can't see much w/ seat in !!! The box can be seen on his web site sp2k com mine is the ported version with cut out for power rear window . I had to cut the hole for the 13" sub (box came built for single 12")also had to install a grill to keep seat off speaker !!
s:
Pro fuzz is offline
post #10 of 15 Old 03-27-2014, 02:35 AM
05krsd's Avatar
I would look at the Sundown Audio SD-2. They are a bigger name in the car audio competition world and if you want something that will hit, they will do it better than JL.
2005 F250 King Ranch, CCSB, FX4, 4.5 inch rough country lift, Edge Evolution tuner, studded, nitto terra grapplers 35s, custom exhaust, intake, hids. SOLD.
Looking for my next powerstroke.
05krsd is offline
