Charging Issues - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Qholic
post #1 of 6 Old 03-20-2014, 08:37 PM Thread Starter
Charging Issues
I have a 2004 F-350 6.0 that is not charging the batteries. The alternator is working properly so I'm guessing I have a broken wire somewhere. Is their anything between the alternator and the battery. Can I just run a new wire from alternator to battery or is it more complicated than that. If I can run a new line is 16 gauge wire sufficient or should I double it up. P.S. I am in a work camp up north so I have no access to stores.
Biozenunity is offline
post #2 of 6 Old 03-21-2014, 05:13 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
16 gauge is like speaker wire; you need 4 gauge as a minimum. You may have blown a fusible link if your not charging. Here is a link with a pic on post #34 that has a diagram showing their location.
DC power altenator install
Go to post # 183 for pics of the fusible links coming off of the alternator.
Bullet proofing started!!!!
Have you put a meter on the alternator to check both volts and amps. An alternator can put out 13-14 volts but almost no amperage and that would prevent your batteries from being charged. Also I would check all of your grounds to make sure they are clean and tight.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
post #3 of 6 Old 04-05-2014, 09:20 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Well said and dead on. I forgot how shiney the copper winding in the DC Power were. I have worked mine pretty hard on many occasions. Mine has the purple tint to it inside the housing. Lol.
My question is: how do you know the alt is working properly if it's not charging??
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 6 Old 04-05-2014, 09:32 PM
Term3's Avatar
Load testing is the only way to know if some of the diodes are toasted.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 6 Old 04-15-2014, 09:00 PM Thread Starter
Thanks for the help it turned out to be a combo of a fusible link blown on one battery and the other being very week.
post #6 of 6 Old 04-16-2014, 09:28 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Glad you got it worked out and thanks for letting us know what was wrong; it may help someone down the road.
skanj0 likes this.
Shawn
The Following User Says Thank You to Qholic For This Useful Post:
skanj0 (04-16-2014)
