My DIY HID Headlight Projectors - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-19-2014, 05:33 PM Thread Starter
c dog's Avatar
I just finished up doing a DIY HID projectors. I bought new stock headlight housings, projectors and HID bulbs/ballast.
I currently run HIDs in the stock hosings and was looking to improve even more. Plus my head lights now are not as clear as they use to be. Cost me about $300 for every thing.
I am still waiting on the bulbs/ballast arrive. It turned out ok for my first time doing this.
My DIY HID Headlight Projectors-imageuploadedbyautoguide1395275540.798539.jpgMy DIY HID Headlight Projectors-imageuploadedbyautoguide1395275560.364987.jpgMy DIY HID Headlight Projectors-imageuploadedbyautoguide1395275577.754875.jpgMy DIY HID Headlight Projectors-imageuploadedbyautoguide1395275596.887618.jpg
My DIY HID Headlight Projectors-imageuploadedbyautoguide1395275467.946868.jpg
c dog is offline
post #2 of 8 Old 03-19-2014, 05:54 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Care to share how you did it and where you got the projectors?
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 8 Old 03-19-2014, 06:04 PM Thread Starter
c dog's Avatar
Retrofitsource.com for the projectors
DDMTuning.com for the HID bulbs/ballast
A1 auto for the stock headlight assembly.
I'll give you the short version. Pretty much you bake (230+- degrees) the headlights in the oven for about 10-15 mins until the sealant softens . After take out and pry it apart.
Cut the back of the light flat. The projector goes into the headlight bulb hole and has a nut that holds it on the back side (the projector is threaded on one side) Then assemble the headlight, bake to reseal it.
Longest part is waiting for the headlights to heat up in the oven. Google it and you will find more in depth how to.
c dog is offline
post #4 of 8 Old 03-21-2014, 01:15 PM
GotTorque's Avatar
Looks great! What projector and bulb/ballast did you actually buy? Part #s?
What do you mean by "cut the back of the light flat"? Actually use a knife/tool and cut the plastic housing smooth to be able to create a tight seal correct?
Is this a Hi and Low beam set up?
Finally, does the ballast plug into the factory wiring? or just wire the ballast in simply? How does it wire in?
Sorry for all the questions but I've been thinking of picking up a set of A1 Harley lights and doing this, so I am very intrigued, and I think other people wouldn't mind learning a little more on lighting! Thanks!
2006 CCSB PowerStroke
-PMM coolant filter and EGR delete
-Gearhead SRL tune
-5" Diamond Eye Exhaust
-20" BMF Novakane's 35" Toyo AT 2s
-All updated ford parts
-Chopped Running boards
-Gotta love the 6.0 haters...
GotTorque is offline
post #5 of 8 Old 03-23-2014, 04:15 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
In on this. Interested in the same for my truck.
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
post #6 of 8 Old 03-24-2014, 01:54 PM Thread Starter
c dog's Avatar
I'll have to get all the parts for you guys in a few days.
c dog is offline
post #7 of 8 Old 03-25-2014, 06:29 AM
GotTorque's Avatar
Thanks man!
-Gearhead SRL tune
post #8 of 8 Old 03-31-2014, 07:31 AM
GotTorque's Avatar
Any update on Part numbers?
-Gearhead SRL tune
