Windshield wiper probs - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-17-2014, 12:30 PM Thread Starter
FiremanDan's Avatar
My wipers turn on when I turn the steering wheel and depress the brake pedal. Any idea what the problem is? I'm gonna get under the dash when I get home, just thought I would throw it out there.
Sent from AutoGuide.com App
04 Ex Limited 4X4 6.0 early, XDP coolant filter, BPD EGR, Rotella T6
FiremanDan is offline
post #2 of 11 Old 03-17-2014, 05:55 PM Thread Starter
FiremanDan's Avatar
Well I looked under the dash for anything that looked out of place, and found nothing. I was thinking it was a wire that may have been between the brake pedal mechanism and the steering column or something. I didn't find anything that appeared out of place. Any ideas where to look next?
post #3 of 11 Old 03-19-2014, 05:30 AM Thread Starter
FiremanDan's Avatar
Any ideas?
post #4 of 11 Old 03-19-2014, 05:34 AM
ZMANN's Avatar
Quoted: 1581 Post(s)
if it weren't for the brake part I would be thinking clockspring but the brake input
might invalidate that idea
We Miss you Ronnie
ZMANN is online now
post #5 of 11 Old 03-19-2014, 08:29 AM Thread Starter
FiremanDan's Avatar
Let me add this, I don't know if it matters or not. Three weeks ago I bled the brakes and bled the power steering. It seems to have started around the same time.
post #6 of 11 Old 03-19-2014, 08:33 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Check for loose connectors under the hood or connectors that might have gotten some fluid in them.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
post #7 of 11 Old 03-19-2014, 12:25 PM Thread Starter
FiremanDan's Avatar
I will, tx!
post #8 of 11 Old 03-19-2014, 06:52 PM Thread Starter
FiremanDan's Avatar
Well, it's getting worse. I was in line at school picking up the kiddos and the wipers just started going and would not stop. I had to pull the fuse to stop them. I looked at the wires under the good and nothing was loose or seemed to have any brake/trans fluid on them. I did put some rags under PS and brake master when I was bleeding them. When it started I did have the wheel turned and my foot was on the brakes. I install the fuse again and it went back to brakes and wheel turns again. I'll just keep looking I reckon. Thanks again!
post #9 of 11 Old 06-04-2014, 12:12 PM Thread Starter
FiremanDan's Avatar
Well, no change. Does anyone know where the wiper relay is located? Only thing I could find about where it might be is behind the AC controls. I haven't taken the dash apart yet to look. Maybe one day
post #10 of 11 Old 06-06-2014, 06:34 AM Thread Starter
FiremanDan's Avatar
I took the dash out and I only see two relays in a box behind the AC control, kinda to the left behind the hidey hole. Neither one match the relay that NAPA sold me. Both are much larger. Any ideas? Its humid and hot outside, Im sick, this is sucking!
