Upfitter switches - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-15-2014, 11:25 AM Thread Starter
Quoted: 84 Post(s)
Upfitter switches
Is there any reason why my upfitter switches would read 24V instead of the 12V, all four seem to be doing this. Thanks for any help.
mikeb01453 is offline
post #2 of 8 Old 03-16-2014, 07:08 AM Thread Starter
Quoted: 84 Post(s)
Has this happened to anyone else? I want to use upfitter switch number 4 for my cb radio which is rated for 12 V, will i be fine using this with my CB or will i risk damaging it?
post #3 of 8 Old 03-16-2014, 07:10 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
What are you using to check the voltage? It would be impossible (unless you have the batteries installed incorrectly) to get 24 volts.
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 8 Old 03-16-2014, 07:20 AM Thread Starter
Quoted: 84 Post(s)
im using a digital multimeter, and i know i was testing the upfitter wires because when i switched the switches off it read zero, and when on they all read 24. I have had no issues whatsoever electrically with the truck and would imagine that improperly installed batteries would probably cause more issues (these are the same batteries the truck came with). perhaps i will check the multimeter to make sure it is still functioning properly.
post #5 of 8 Old 03-16-2014, 07:25 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Yeah, I would check that with another multimeter
Please
The Following User Says Thank You to NYC F-350 For This Useful Post:
mikeb01453 (03-20-2014)
post #6 of 8 Old 03-16-2014, 07:40 AM Thread Starter
Quoted: 84 Post(s)
i hope the multimeter is the problem haha
post #7 of 8 Old 03-16-2014, 09:18 AM
supreme oppressor's Avatar
Low batteries on the multimeter can cause screwy readings.
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
post #8 of 8 Old 03-16-2014, 11:56 AM Thread Starter
Quoted: 84 Post(s)
it was the multimeter, its odd how it exactly doubled what the correct reading was... But anyways, thanks for the help guys. NYC f350 thats twice youve helped me this week so thank you for your time.
